[GRASS-user] R, Moran index, getis e ord.....
    Robbie Heremans
    robbie.heremans at gmail.com
    Fri Oct  1 15:05:39 EDT 2010
Maybe http://www.asdar-book.org/ can help you. Have a look in "Additional
materials".
Robbie
2010/9/30 Gabriele N. <gis.gn at libero.it>
> Hello everyone.
> I have a raster which is the result of calculating an index of remote
> sensing (with decimals).
> I would like to calculate the Moran's index and the index of Getis and Ord
> To do this I installed R (following
> http://grass.fbk.eu/statsgrass/grass6_r_install.html).
> Then I installed the packages
> install.packages("spdep",dependencies=TRUE)
> install.packages("maptools",dependencies=TRUE)
> Then from the shell:
> R
> Then load these libraries
> library(spgrass6)
> library(spdep)
> library(maptools)
> library(boot)
> library(Matrix)
> library(lattice)
> I read the raster
> index_water_2009<-readRAST6("index_water_2009")
> At this point I stopped. I saw on the mailing list and some tutorials.
> I can not understand the syntax to use.
> It only works on vector?
> Someone can give me some help?
> Thanks
> http://osgeo-org.1803224.n2.nabble.com/R-Moran-index-getis-e-ord-tp5588509p5588509.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20101001/0587fdd0/attachment.html
