[GRASS-user] Re: self compile grass- msys
    António Rocha
    antonio.rocha at deimos.com.pt
    Wed Oct  6 10:56:09 EDT 2010
Hi there
I have sent a similar message to this
http://lists.osgeo.org/pipermail/grass-user/2010-September/057903.html
but to the wingrass mailing list.
Since there is no follow up on this subject in this mailing list I
wanted to know if anyone found any answer to this? Because I'm having
the same problem in winWXP 32. In the past I had this Windows GRASS
compilation and now, I decided to have it again but I'm having this problem:
checking whether to use Curses... yes
checking for curses.h... yes
checking curses.h WINDOW structure component... _maxy
checking for initscr in -lncurses... no
checking for initscr in -lcurses... configure: error: *** Unable to
locate curses library.
no
Regarding -lncurses, my config.log has the following:
int main() {
WINDOW w; w.maxy = 0;
; return 0; }
configure:5691: gcc -c -g -O2    -I/c/OSGeo4W/apps/gdal-16/include
-I/c/OSGeo4W/include conftest.c 1>&5
configure:5707: checking for initscr in -lncurses
configure:5724: gcc -o conftest.exe -g -O2
-I/c/OSGeo4W/apps/gdal-16/include -I/c/OSGeo4W/include
-Wl,--export-dynamic,--enable-runtime-pseudo-reloc
-L/c/OSGeo4W/apps/gdal-16/lib -L/c/OSGeo4W/lib conftest.c -lncurses   1>&5
c:/mingw/bin/../lib/gcc/mingw32/4.5.0/../../../../mingw32/bin/ld.exe:
warning: --export-dynamic is not supported for PE targets, did you mean
--export-all-symbols?
cannot find -lncurses
collect2: ld returned 1 exit status
configure: failed program was:
#line 5713 "configure"
#include "confdefs.h"
/* Override any gcc2 internal prototype to avoid an error.  */
/* We use char because int might match the return type of a gcc2
    builtin and then its argument prototype would still apply.  */
char initscr();
And regarding lcurses, it's the following:
int main() {
initscr()
; return 0; }
configure:5743: checking for initscr in -lcurses
configure:5760: gcc -o conftest.exe -g -O2
-L/c/OSGeo4W/apps/gdal-16/lib -L/c/OSGeo4W/lib conftest.c -lcurses   1>&5
c:/mingw/bin/../lib/gcc/mingw32/4.5.0/../../../crt2.o:crt1.c:(.text+0x28):
undefined reference to `__dyn_tls_init_callback'
#line 5749 "configure"
char initscr();
What is missing in my installation? Because I have checked, and my
osgeo4W includes pdcurses-devel
Thanks
Antonio
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5509 (20101006) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
