[GRASS-user] Meta Data Management Suggestions
maning sambale emmanuel.sambale at gmail.com
Wed Oct 6 22:27:57 EDT 2010
For individual layers in GRASS, you can add descriptive information
and processing history using r.support.
To access the information, use r.info.
Many metadata support files in GRASS are simple text files.
A simple shell script can parse that data and reformatted into a human
readable format.
On Thu, Oct 7, 2010 at 10:20 AM, stephen sefick <ssefick at gmail.com> wrote:
> I would like to keep metadata files for the maps that I import into
> GRASS and also the maps that I create.  Much like the metadata that is
> provided by ... cough... ESRI.  Is there a way to do this in GRASS?
> Should I just store the meta data files as text files in the GRASS
> location and then edit them with the additional GRASS processing
> information?
> thanks,
> Stephen Sefick
> ____________________________________
> | Auburn University                                   |
> | Department of Biological Sciences           |
> | 331 Funchess Hall                                  |
> | Auburn, Alabama                                   |
> | 36849                                                    |
> |___________________________________|
> | sas0025 at auburn.edu                             |
> | http://www.auburn.edu/~sas0025             |
> Let's not spend our time and resources thinking about things that are
> so little or so large that all they really do for us is puff us up and
> make us feel like gods.  We are mammals, and have not exhausted the
> annoying little problems of being mammals.
>                                 -K. Mullis
> "A big computer, a complex algorithm and a long time does not equal science."
>                               -Robert Gentleman
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
