[GRASS-user] Re: Question regarding Wiki: Compiling GRASS on MS-Windows
Kim Besson kimbesson1981 at gmail.com
Thu Oct 7 04:58:27 EDT 2010
Glynn mentioned some possible error associated with gcc version. Any
comments about this?
As far as I can see Thy had the same problem last week and antonio is also
having this problem. I talked with Antonio and he told me that he never had
this problem before. Only now...
Which means that this has something to do with a new improvement/update of
osgeo4w or similar
2010/10/6 Helmut Kudrnovsky <hellik at web.de>
> >Greetings
> >I'm using the version that is diretly linked in CompileOnWindows WIKI
> >because I'm not being able to identify and corretcly select newer versions
> >for msysCORE-1.0.11-bin, bin-utils, gcc-core, gcc-g++, etc.
> >Can this be a limitation?
> AFAICT I'm using the linked version from the WIKI in my
> WinGrass-build-environment.
> IMHO there should be no limitation.
> best regards
> Helmut
> ___________________________________________________________
> Neu: WEB.DE De-Mail - Einfach wie E-Mail, sicher wie ein Brief!
> Jetzt De-Mail-Adresse reservieren: https://produkte.web.de/go/demail02
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20101007/75306657/attachment.html
