[GRASS-user] Projection Question units to use for resolution (m or
ft)
stephen sefick
ssefick at gmail.com
Thu Oct 7 09:19:00 EDT 2010
I have a location in the current projection:
code:
r.prog -p
result:
-PROJ_INFO-------------------------------------------------
name : Lambert Conformal Conic
proj : lcc
datum : nad83
ellps : grs80
lat_1 : 36.16666666666666
lat_2 : 34.33333333333334
lat_0 : 33.75
lon_0 : -79
x_0 : 609601.2192024384
y_0 : 0
no_defs : defined
towgs84 : 0.000,0.000,0.000
-PROJ_UNITS------------------------------------------------
unit : US survey foot
units : US survey feet
meters : 0.3048006096012192
This is NC State Plane 3200 FIPS (ft)
I am going to be importing bare ground xyz LIDAR tiles to interpolate
with surf.idw. I would like the finished product to be a 1m
resolution DEM. Do I set the resolution in m (1) or ft (3.280833)?
Thanks you for all of your help.
Stephen Sefick
____________________________________
| Auburn University |
| Department of Biological Sciences |
| 331 Funchess Hall |
| Auburn, Alabama |
| 36849 |
|___________________________________|
| sas0025 at auburn.edu |
| http://www.auburn.edu/~sas0025 |
Let's not spend our time and resources thinking about things that are
so little or so large that all they really do for us is puff us up and
make us feel like gods. We are mammals, and have not exhausted the
annoying little problems of being mammals.
-K. Mullis
"A big computer, a complex algorithm and a long time does not equal science."
-Robert Gentleman
