[GRASS-user] r.univar.zonal not installing
Laura Poggio
laura.poggio at gmail.com
Fri Oct 8 04:43:41 EDT 2010
Dear all,
it worked using g.extension on an updated version of GRASS65.
Sorry for my late answer but in the past days I was unable to try.
Thank you
Laura
On 5 October 2010 20:17, Markus Neteler <neteler at osgeo.org> wrote:
> On Mon, Aug 9, 2010 at 5:41 PM, Laura Poggio <laura.poggio at gmail.com>
> wrote:
> > Dear all,
> > since a while, I am trying to compile the r.univar.zonal addon on a
> Fedora11
> > 64 bit machine and using GRASS 6.5
> > I used:
> > svn co https://svn.osgeo.org/grass/grass-addons/raster/r.univar2.zonal
> > cd r.univar2.zonal/
> > make MODULE_TOPDIR=~/bin/grass65/grass6_devel/
> > No errors were detected, but when I try:
> > make MODULE_TOPDIR=/home/myuser/bin/grass65/grass6_devel install
> > I am getting:
> > if [ "" != "" ] ; then \
> > for dir in ; do \
> > make -C $dir install ; \
> > done ; \
> > fi
> > Various other addons were installed using these steps, then I think I am
> > missing something here ... Thank you in advance for any hints!
> Perhaps that comes from the directory name which I find slightly confusing:
> GRASS 6.4.1svn (nc_spm_08):~ > ls -la grass-addons/raster/r.univar2.zonal/
> total 76
> drwxr-xr-x 3 neteler neteler 4096 2010-02-18 21:40 ./
> drwxr-xr-x 53 neteler neteler 4096 2010-09-23 12:04 ../
> -rw-r--r-- 1 neteler neteler 1806 2010-02-18 21:36 globals.h
> -rw-r--r-- 1 neteler neteler 624 2009-04-09 10:44 Makefile
> -rw-r--r-- 1 neteler neteler 8426 2010-02-18 21:36 r3.univar_main.c
> -rw-r--r-- 1 neteler neteler 2286 2010-02-18 21:36 r3.univar.zonal.html
> -rw-r--r-- 1 neteler neteler 9829 2010-02-18 21:36 r.univar_main.c
> -rw-r--r-- 1 neteler neteler 4411 2009-04-09 10:44 r.univar.zonal.html
> -rw-r--r-- 1 neteler neteler 3358 2009-02-24 08:27 sort.c
> -rw-r--r-- 1 neteler neteler 15223 2010-02-18 21:36 stats.c
> drwxr-xr-x 6 neteler neteler 4096 2010-09-22 09:25 .svn/
> GRASS 6.4.1svn (nc_spm_08):~ > grep univ
> grass-addons/raster/r.univar2.zonal/Makefile
> PROGRAMS = r.univar.zonal r3.univar.zonal
> R3UNIVAR = $(BIN)/r3.univar.zonal$(EXE)
> RUNIVAR = $(BIN)/r.univar.zonal$(EXE)
> $(RUNIVAR): $(OBJDIR)/r.univar_main.o $(OBJDIR)/sort.o $(OBJDIR)/stats.o
> $(R3UNIVAR): $(OBJDIR)/r3.univar_main.o $(OBJDIR)/sort.o $(OBJDIR)/stats.o
> -> PROGRAMS that does not reflect the directory name.
> GRASS 6.4.1svn (nc_spm_08):~ > g.extension r.univar.zonal
> WARNING: GRASS_ADDON_PATH is not defined, installing to ~/.grass6/addons/
> Fetching <r.univar.zonal> from GRASS-Addons SVN (be patient)...
> svn: URL 'https://svn.osgeo.org/grass/grass-addons/raster/r.univar.zonal'
> doesn't exist
> ERROR: GRASS Add-on r.univar.zonal not found in repository or no network
> connection or another problem
> But like this it works:
> GRASS 6.4.1svn (nc_spm_08):~ > g.extension r.univar2.zonal
> Fetching <r.univar2.zonal> from GRASS-Addons SVN (be patient)...
> A r.univar2.zonal/stats.c
> A r.univar2.zonal/sort.c
> A r.univar2.zonal/globals.h
> A r.univar2.zonal/r.univar.zonal.html
> A r.univar2.zonal/r.univar_main.c
> A r.univar2.zonal/r3.univar.zonal.html
> A r.univar2.zonal/r3.univar_main.c
> A r.univar2.zonal/Makefile
> U r.univar2.zonal
> Checked out revision 43799.
> Compiling <r.univar2.zonal>...
> test -d OBJ.x86_64-unknown-linux-gnu || mkdir -p
> gcc -I/home/neteler/grass64/dist.x86_64-unknown-linux-gnu/include -g
> -Wall -fno-common -fexceptions -mtune=nocona -m64
> -minline-all-stringops -DPACKAGE=\""grassmods"\"
> -I/home/neteler/grass64/dist.x86_64-unknown-linux-gnu/include -o
> OBJ.x86_64-unknown-linux-gnu/r.univar_main.o -c r.univar_main.c
> Proposals
> @authors: rename directory to first program name
> @Laura: please try g.extension
> best,
> Markus
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20101008/9b2705ae/attachment.html
