[GRASS-user] configuration of spgrass6 with grass 65 svn
Maris Nartiss
maris.gis at gmail.com
Fri Oct 8 05:36:48 EDT 2010
How about fixing error You got? I'ts quite clear - GRASS not running.
Start GRASS and then from within GRASS start R.
Second option is to set all required GRASS env variables.
Maris.
2010/10/7, Ricardo RodrÃguez <ricardorodot02 at gmail.com>:
> hi all, how I can configure spgrass6 to work with svn 6.5 Gis grass because
> I get the next instance in the console
>> library(spgrass6)
> Loading required package: sp
> Loading required package: rgdal
> Geospatial Data Abstraction Library extensions to R successfully loaded
> Loaded GDAL runtime: GDAL 1.7.2, released 2010/04/23
> Path to GDAL shared files: /usr/share/gdal17
> Loaded PROJ.4 runtime: Rel. 4.7.1, 23 September 2009
> Path to PROJ.4 shared files: (autodetected)
> Loading required package: XML
> GRASS GIS interface loaded with GRASS version: *(GRASS not running)*
> some idea about, thanks for your help and time.
> Ricardo RodrÃguez
> Univalle
