[GRASS-user] Generating DEM from bare ground LIDAR data:
v.surf.idw or v.surf.bspline ?
Markus Metz
markus.metz.giswork at googlemail.com
Mon Oct 11 03:44:31 EDT 2010
stephen sefick wrote:
> I have a multitude of DEMs to generate at 1m resolution. Are there
> any references that compare v.surf.idw and v.surf.bspline? Any advice
> or experience with either of these two modules would be helpful.
> Which one of these modules creates the most accurate representation of
> the surface. This will be with NC data- in fact the same 2001 data
> that is included in the new GRASS dataset. I am working on a project
> in NC if this helps. Thank you for all of your help, and I will
> provide any information that you may need. Also, if I use
> v.surf.bspline is the 1.5*point average point spacing still the rule
> of thumb (the point spacing is found with running v.surf.bspline with
> the -e flag?).
The 1.5 * average point spacing is a useful rule of thumb as long as
the points are evenly spaced as e.g. for elev_lid792_bepts in the
North Carolina sample database. If the points are not evenly spaced,
e.g. strips with high density, but the strips are separated by a
distance larger than the average within-strip distance (e.g.
contours), then the spline step values need to be adjusted, no
established rule of thumb here.
We need a wiki page explaining the different interpolation methods...
Markus M
Thank you so much for all of your help.
> Stephen Sefick
> ____________________________________
> | Auburn University |
> | Department of Biological Sciences |
> | 331 Funchess Hall |
> | Auburn, Alabama |
> | 36849 |
> |___________________________________|
> | sas0025 at auburn.edu |
> | http://www.auburn.edu/~sas0025 |
> Let's not spend our time and resources thinking about things that are
> so little or so large that all they really do for us is puff us up and
> make us feel like gods. We are mammals, and have not exhausted the
> annoying little problems of being mammals.
> -K. Mullis
> "A big computer, a complex algorithm and a long time does not equal science."
> -Robert Gentleman
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
