[GRASS-user] v.db.join script
Jon Eiriksson jeir at hi.is
Thu Oct 14 09:32:15 EDT 2010
Thank you for the response,
I ran the same data with sqlite, and this is what I get with
db.describe -c:
[sqlite db]
GRASS 6.4.0 (spearfish60):~ > db.describe -c mysoils
ncols: 5
nrows: 54
Column 1: cat:INTEGER:20
Column 2: label:CHARACTER:13
Column 3: id:CHARACTER:1
Column 4: shortname:CHARACTER:1
Column 5: longname:CHARACTER:1
GRASS 6.4.0 (spearfish60):~ > db.describe -c soils_legend
ncols: 3
nrows: 55
Column 1: id:CHARACTER:1
Column 2: shortname:CHARACTER:1
Column 3: longname:CHARACTER:1
- and there is no truncation of data after v.db.join,
while
[mysql db]
ncols: 5
nrows: 54
Column 1: cat:INTEGER:11
ncols: 3
nrows: 55
Column 1: id:CHARACTER:255
Column 2: shortname:CHARACTER:255
Column 3: longname:CHARACTER:255
- truncates the data in joined columns
I do not have a suggestion for an improved script - not up to that
yet. The mysql db seems to be more strict as to the column variable
length definition. As you point out, the definition is ignored and
data carried over differently in sqlite and mysql. Hope that someone
can take this up.
Thanks, Jon
On 13.10.2010, at 20:23, Micha Silver wrote:
> On 10/12/2010 12:01 PM, Jon Eiriksson wrote:
>> Hi,
>> I have a truncation problem with v.db.join. This has been raised
>> before -
>> ([GRASS-user] Re: grass v.db.join
>> Gary Nobles
>> Fri, 12 Mar 2010 11:11:26 -0800)
>> - but I have not seen a solution. I have tried my own data, the
>> spearfish60 example data, and the example in Neteler and Mitasova's
>> book.
>> The new data columns are apparently defined as 1 character long,
>> and the
>> data become truncated accordingly, much against my intention. I use
>> mysql.
> I can see why this is happening. But I'm not sure what the correct
> solution might be. v.db.join is a wrapper around db.describe and
> v.db.addcol. When I query an sqlite database connection here's what
> the output looks like:
> db.describe -c bike_rides2
> ncols: 8
> nrows: 17
> Column 2: name:CHARACTER:80
> Column 3: number:INTEGER:20
> Column 4: comment:CHARACTER:80
> Column 5: descriptio:CHARACTER:80
> Column 6: source:CHARACTER:80
> Column 7: url:CHARACTER:80
> The output format is obviously:
> "Column num:column name:column type:column size".
> One line from the v.db.join script uses grep and cut to get the
> column names and the next line gets the column types like so:
> db.describe -c bike_rides2 | grep '^Column' | cut -d ':' -f 3
> INTEGER
> CHARACTER
> INTEGER
> CHARACTER
> CHARACTER
> CHARACTER
> CHARACTER
> So the column size is actually ignored.
> Next, in the script the above output is used by v.db.addcol to
> create the new columns in the joined vector. So all new character
> columns are created as a single char and the actual length is never
> used.
> Questions:
> Is the db.describe output the same for all db drivers?
> Any suggestions how to fix this as a script?
> Or better, just convert to python?
> Thanks,
> Micha
> Micha Silver
> Arava Development Co. +972-52-3665918
> http://www.surfaces.co.il
Jon Eiriksson, Research Professor,
Earth Science Institute, University of Iceland,
Askja, Sturlugata 7,
IS-101 Reykjavik, Iceland.
Tel     +354 525 44 75
Fax     +354 525 44 99
Email   jeir at hi.is
Web    http://www.raunvis.hi.is/~jeir/
