[GRASS-user] cut raster
Daniel Victoria
daniel.victoria at gmail.com
Thu Oct 14 10:37:14 EDT 2010
Hi Sofina,
The way I normally do this is first, convert the vetor to raster
(v.to.rast). Then I transform the converted newlly created raster to a
mask (r.mask) and, using r.mapcalc, clip the satellite image. Don't
forget to latter remove the raster mask.
The commands performed would be something like this:
v.to.rast input=building_vector output=build_raster
r.mask build_raster
r.mapcalc
clipped_sat = satellite_image
r.mask -r
@ Grass List.
I can't recall if there is an easier way to do this... Maybe a script?
Such a simple procedure should be done easily in one step...
Cheers
Daniel
On Thu, Oct 14, 2010 at 10:16 AM, Sofina Natalia <nsofina at gmx.de> wrote:
> Hi everybody! I'm a beginner with GRASS... I have a lot of questions. Now I
> need to cut out an area from a satellite image according a relevant vector
> object from digital map. I need to cut out a building from satellite image,
> that I have as a vector object, and save it to the new raster map (only one
> building). Or may be it's possible to cut out an area from a satellite image
> using coordinates from vector object.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
