[GRASS-user] Startup error with 6.4.1svn on OSX 10.6.4
Stuart Edwards sedwards2 at cinci.rr.com
Thu Oct 14 11:13:14 EDT 2010
On Oct 14, 2010, at 11:00 AM, William Kyngesburye wrote:
> The GRASS package seems to be incomplete - it's running the system wxpython, but linking the bundled wx libraries, which are probably much newer and incompatible with the system.  If both wxpython and wx libraries are bundled, then maybe the bundled wxpython is not in the python path (it should be in etc/python in the GRASS app package).
> Did you build from source?  Or install a binary (I think Michael Barton has a svn binary available)?
Yes, from source.
> On Oct 14, 2010, at 8:42 AM, Stuart Edwards wrote:
>> Hi -
>> OSX 10.6.4
>> I have installed 6.4.1svn and get the following startup error:
>> '/Applications/GRASS-6.4.app/Contents/MacOS/grass.sh'; exit
>> SEsMacPro:~ stu$ '/Applications/GRASS-6.4.app/Contents/MacOS/grass.sh'; exit
>> Rebuilding Addon HTML manual pages index...
>> Rebuilding Addon menu...
>> Python 2.6.1 found.
>> Cleaning up temporary files ...
>> Starting GRASS ...
>> ERROR: wxGUI requires wxPython. dlopen(/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/wx-2.8-mac-unicode/wx/_controls_.so, 2): Symbol not found: __ZN10wxListCtrl19GetBackgroundColourEv
>> Referenced from: /System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/wx-2.8-mac-unicode/wx/_controls_.so
>> Expected in: /Applications/GRASS-6.4.app/Contents/MacOS/lib/libwx_macud-2.8.0.dylib
>> in /System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/wx-2.8-mac-unicode/wx/_controls_.so
>> Error in GUI startup. If necessary, please
>> report this error to the GRASS developers.
>> Switching to text mode now.
>> Hit RETURN to continue...
>> I was using 6.4.0 immediately prior with the wxpython gui so it's there ........
>> Thanks for any assistance -
>> Stu
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "This is a question about the past, is it? ... How can I tell that the past isn't a fiction designed to account for the discrepancy between my immediate physical sensations and my state of mind?"
> - The Ruler of the Universe
