[GRASS-user] Error when running a scrip in Windows-WinGRASS
M.Onur Kurum
mokurum at ncsu.edu
Thu Oct 14 13:00:22 EDT 2010
I completely removed the Python25 bundled with GRASS and changed the
startup bat file to not look for the bundled python so this is how it goes:
C:\GRASS-70-SVN>set_shell_start_grass70svn.bat
Cleaning up temporary files...
Starting GRASS GIS...
File "C:\GRASS-70-SVN\etc\gui\wxpython\gis_set.py", line 38, in <module>
import gui_modules.goutput
File "C:\GRASS-70-SVN\etc\gui\wxpython\gui_modules\goutput.py", line
35, in <module>
import gcmd
File "C:\GRASS-70-SVN\etc\gui\wxpython\gui_modules\gcmd.py", line 44,
in <module>
from win32file import ReadFile, WriteFile
ImportError: No module named win32file
Error in GUI startup. If necessary, please report this error to the
GRASS developers.
Switching to text mode now.
Hit RETURN to continue...
File "C:\GRASS-70-SVN\grass70.py", line 956, in <module>
set_data()
File "C:\GRASS-70-SVN\grass70.py", line 497, in set_data
gui_startup()
File "C:\GRASS-70-SVN\grass70.py", line 519, in gui_startup
os.execlp(cmd_name, "-text")
File "C:\Python26\lib\os.py", line 327, in execlp
execvp(file, args)
File "C:\Python26\lib\os.py", line 344, in execvp
_execvpe(file, args)
File "C:\Python26\lib\os.py", line 380, in _execvpe
func(fullname, *argrest)
OSError: [Errno 2] No such file or directory
I guess this is what you meant with
"The only thing which may be problematic is the wxPython digitiser module. "
for windows grass 7 comes bundled with python25 and now I use python26
installed separately.
Could you be more specific about how to remove the module ? I am lost there.
in the bundled \Python25\Lib\site-packages\wx-2.8-msw-unicode I see that
wxpython is
Metadata-Version: 1.0
Version: 2.8.9.1 for python 2.5
and the one in \Python26\Lib\site-packages\wx-2.8-msw-unicode is version
2.8.11.0 for python 2.6
thanks
Onur
On 10/14/2010 2:44 AM, Glynn Clements wrote:
> M.Onur Kurum wrote:
>> Any ideas, suggestions ?
>> I just want to be able to launch the GUI when I have a .py of my own
>> under /scripts in grass6.4 or 7.0
> For 7.0, remove any version of Python which is bundled with GRASS, and
> remove any reference to it from the startup scripts. Just use the
> installed version of Python.
> module. That includes a binary component which will only work with the
> exact versions of Python and wxPython for which it was compiled. If
> this module is present, you may need to remove it in order to start
> the GUI.
M.Onur Kurum
Graduate Research Assistant
Dept. of Civil, Construction, and Environmental Engineering
North Carolina State University
Campus Box 7908
2501 Stinson Drive, 428 Mann Hall
Raleigh, NC 27695-7908
Office: (919) 515-1340
Mobile: (919) 200-0665
Email: mokurum at ncsu.edu
Email: m.onur.kurum at gmail.com
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20101014/774017d7/attachment.html
