[GRASS-user] Startup error with 6.4.1svn on OSX 10.6.4
Stuart Edwards sedwards2 at cinci.rr.com
Thu Oct 14 14:41:24 EDT 2010
On Oct 14, 2010, at 11:36 AM, William Kyngesburye wrote:
>>> The GRASS package seems to be incomplete - it's running the system wxpython, but linking the bundled wx libraries, which are probably much newer and incompatible with the system.  If both wxpython and wx libraries are bundled, then maybe the bundled wxpython is not in the python path (it should be in etc/python in the GRASS app package).
>>> Did you build from source?  Or install a binary (I think Michael Barton has a svn binary available)?
>> Yes, from source.
> Are you using the system wxpython or did you install a binary from wxpython.org? (note: the system wxpython is a bit old, though it fits the minimum needed for GRASS)
It's the system wxpython
> Are you explicitly bundling wxpython?  If not, it's odd that it thinks the wx libraries are bundled (the "expected in..." part of the error).
No, I did the export nad2bin line and then configured with the given (long) ./configure  (which doesn't appear to mention python or wxpython........)
I did not do the '--with-python  --with-wxwidgets=/usr/local/lib/wxPython-unicode-x.x.x.x/bin/wx-config modification
>>> On Oct 14, 2010, at 8:42 AM, Stuart Edwards wrote:
>>>> Hi -
>>>> OSX 10.6.4
>>>> I have installed 6.4.1svn and get the following startup error:
>>>> '/Applications/GRASS-6.4.app/Contents/MacOS/grass.sh'; exit
>>>> SEsMacPro:~ stu$ '/Applications/GRASS-6.4.app/Contents/MacOS/grass.sh'; exit
>>>> Rebuilding Addon HTML manual pages index...
>>>> Rebuilding Addon menu...
>>>> Python 2.6.1 found.
>>>> Cleaning up temporary files ...
>>>> Starting GRASS ...
>>>> ERROR: wxGUI requires wxPython. dlopen(/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/wx-2.8-mac-unicode/wx/_controls_.so, 2): Symbol not found: __ZN10wxListCtrl19GetBackgroundColourEv
>>>> Referenced from: /System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/wx-2.8-mac-unicode/wx/_controls_.so
>>>> Expected in: /Applications/GRASS-6.4.app/Contents/MacOS/lib/libwx_macud-2.8.0.dylib
>>>> in /System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/wx-2.8-mac-unicode/wx/_controls_.so
>>>> Error in GUI startup. If necessary, please
>>>> report this error to the GRASS developers.
>>>> Switching to text mode now.
>>>> Hit RETURN to continue...
>>>> I was using 6.4.0 immediately prior with the wxpython gui so it's there ........
>>>> Thanks for any assistance -
>>>> Stu
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "We are at war with them. Neither in hatred nor revenge and with no particular pleasure I shall kill every ___ I can until the war is over. That is my duty."
> "Don't you even hate 'em?"
> "What good would it do if I did? If all the many millions of people of the allied nations devoted an entire year exclusively to hating the ____ it wouldn't kill one ___ nor shorten the war one day."
> <Ha, ha> "And it might give 'em all stomach ulcers."
> - Tarzan, on war
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20101014/c33c79d9/attachment-0001.html
