[GRASS-user] Rename Location using dbf driver
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Fri Oct 15 14:33:34 EDT 2010
On Friday 15 of October 2010 21:11:13 ssefick wrote:
> I would like to rename a couple of locations. I am using the dbf driver
> for the database. Can I safely just rename the folder of the location?
> Thanks in advance.
Stephen,
I think renaming is not enough. You have to "reconnect" the data bases
afterwards. Check the "v.db.reconnect.all" module/manual. There are also older
posts about that in the mailing list archive.
Cheers, Nikos
