[GRASS-user] Question about r.in.xyz
Franz Schiller franzschiller1975 at gmail.com
Mon Oct 18 12:26:09 EDT 2010
Hello there
I have a simple question related with r.in.xyz:
When I import a ASCII file I do this:
r.in.xyz input="C:\Test_areas\graphbased\filev2" output="v2 at PERMANENT"
But in the metadata I get the following:
- number of categories: 255 => Why is this? I haven't set anything
- and in the r.info v2 I get a command slightly different from the one I
typed:
r.in.xyz input="C:\Test_areas\graphbased\saidav2" output="v2 at PERMANENT"
method="mean" type="FCELL" fs=" " x=1 y=2 z=3 zscale=1.0 percent=100
Why?
Sorry for bothering you with this but, this is relevant for my work
Thanks
Franz
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20101018/d65a9073/attachment.html
