[GRASS-user] error compiling grass65svn and addons for grass64
Laura Poggio laura.poggio at gmail.com
Wed Oct 20 11:23:07 EDT 2010
Yes I have gcc, g++, make.
The full error message for one extension is pasted below (for one extension
as example).
Thank you very much
Laura
Checked out revision 43978.
Compiling <r.stream.basins>...
In file included from catchment.c:1:
global.h:5:23: error: grass/gis.h: No such file or directory
global.h:6:24: error: grass/Vect.h: No such file or
directory
global.h:7:27: error: grass/glocale.h: No such file or
directory
global.h:64: error: expected ‘=’, ‘,’, ‘;’,
‘asm’ or ‘__attribute__’ before ‘*’ token
catchment.c: In function ‘find_outlets’:
catchment.c:29: warning: cast to pointer from integer of
different size
catchment.c:36: error: ‘streams’ undeclared (first use
in this function)
catchment.c:36: error: (Each undeclared identifier is
reported only once
catchment.c:36: error: for each function it appears in.)
catchment.c:45: warning: cast to pointer from integer of
different size
catchment.c:48: error: ‘dirs’ undeclared (first use in
this function)
catchment.c: In function ‘reset_catchments’:
catchment.c:115: error: ‘streams’ undeclared (first use
in this function)
catchment.c: In function ‘fill_catchments’:
catchment.c:147: error: ‘streams’ undeclared (first use
in this function)
catchment.c:159: error: ‘dirs’ undeclared (first use in
this function)
make: *** [OBJ.x86_64-unknown-linux-gnu/catchment.o] Error 1
ERROR: Compilation failed, sorry. Please check above error messages.
test -d OBJ.x86_64-unknown-linux-gnu || mkdir -p
gcc
-I/usr/src/packages/BUILD/grass-6.4.0/dist.x86_64-unknown-linux-gnu/include
-O2    -I/usr/include/gdal/     -DPACKAGE=\""grassmods"\"
-o OBJ.x86_64-unknown-linux-gnu/catchment.o -c catchment.c
(Wed Oct 20 11:56:21 2010) Command finished (6
sec)
On 20 October 2010 14:38, <razmjooeis at faunalia.co.uk> wrote:
> Have you got the following packges installed?
> gcc
> g++
> make
> Cheers
> Sab
> > Hello,
> > You have to provide whole error message. Without exact error text,
> > it's impossible to tell what kind of problem You have.
> > WBR,
> > Maris.
> > 2010/10/20, Laura Poggio <laura.poggio at gmail.com>:
> >> Dear all,
> >> I installed grass6.4 on a machine with Suse11.2 64 bit from the official
> >> repository. Then I tried to install  some addons with g.extension and
> >> using
> >> the usual configure/make/make install.
> >> In both cases I get the following error:
> >> make: *** [OBJ.x86_64-unknown-linux-gnu/[...]] Error 1
> >> I also tried to compile grass65 from svn and I am getting the same
> >> error.
> >> Please let me know and I can provide more details. Sorry but I do not
> >> know
> >> what would be useful for better understanding the problem.
> >> Thank you very much in advance
> >> Laura
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20101020/114284ec/attachment.html
