[GRASS-user] r.reclass with floating point result
Hanlie Pretorius hanlie.pretorius at gmail.com
Thu Oct 21 00:36:00 EDT 2010
2010/10/19, Glynn Clements <glynn at gclements.plus.com>:
> Hanlie Pretorius wrote:
>> So, I have two problems here: 1) I can't get r.reclass to output an
>> FCELL raster even though its help file suggest that only the input
>> file needs to be a CELL raster.
> A reclass table maps integers to integers. You cannot generate a
> floating-point map by reclassing.
Could you perhaps suggest a method to do so? I tried r.mapcalc, but I
also got a conversion to integers. Somehow the default raster is an
integer raster?
