[GRASS-user] Re: v.in.ascii
    Duccio Rocchini
    ducciorocchini at gmail.com
    Thu Oct 21 08:22:19 EDT 2010
First, check your separator and explicitly state it by the fs parameter
e.g. fs=' ' or fs='\t', etc.
If you are using headers make use of skip
e.g.  skip=1 the first line is the header
you could explicitly state what are the columns with x and y
# x=2 explicitly states that x is the second column
# y=3 explicitly states that y is the third column
here is an example:
v.in.ascii input=/your_path/your_file.asc output=name fs=' '
columns='point_id varchar(20), x double precision, y double precision' x=2
y=3 skip=1 --o
here is the input file (example in utm_wgs84 zone 32N)
point_id x y
point1 575225.75 4785221.74
point2 575229.78 4785227.41
etc.
Hope this helps!
Duccio
> -------- Messaggio originale --------
> Oggetto:        [GRASS-user] v.in.ascii
> Data:   Thu, 21 Oct 2010 12:15:56 +0200
> Mittente:       Luca Cinquepalmi <cinquepalmi at planetek.it>
> Organizzazione:         Planetek Italia s.t.l. +39 080 9644200
> A:      grass-user at lists.osgeo.org
> Hi. I started with grass and whne i use the v.in.ascci comand the wollowing
> message appears.
> ERROR: y column number>  minimum last column number
> (incorrect field separator?)
> what does it mean? is there another method to import ascci file? thanks
> Luca
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL:
> http://lists.osgeo.org/pipermail/grass-user/attachments/20101021/3157718e/attachment-0001.html
> Message: 5
> Date: Thu, 21 Oct 2010 11:32:08 +0100
> From: Monica Buescu <monicabuescu1985 at gmail.com>
> Subject: Re: [GRASS-user] Use of r.mode
> Cc: GRASS user list <grass-user at lists.osgeo.org>
> Message-ID:
>        <AANLkTintNHzbKeJPpsihEE8YNDS-E-jFdZ0nSDPswTD2 at mail.gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"
> > Well, that's not good. Yes, maybe a problem with disk space or memory?
> l'll
> have to leave to someone more knowledgeable to answer here.
> Thanks Micha
> Probaby in this case is "Memory" space. Because for Smaller images I don't
> get any problem and bigger images I'm getting this problem.
> As anyone experienced such a problem? (GRASS takes toooooo long to display
> an image or apply r.mapcalc?
> URL:
> http://lists.osgeo.org/pipermail/grass-user/attachments/20101021/0a7a7d41/attachment-0001.html
> Message: 6
> Date: Thu, 21 Oct 2010 11:43:51 +0100
> From: Kim Besson <kimbesson1981 at gmail.com>
> Subject: Re: [GRASS-user] Type of data to be used in i.maxlik
> To: GRASS user list <grass-user at lists.osgeo.org>
> Message-ID:
>        <AANLkTinXf2V9m6340=YE1j=qWrf35PDEhc-9MigCBsPC at mail.gmail.com>
> Hi Markus
> >> The input can be double but will be read as integer (CELL) since the
> >> function
> >> G_open_cell_old() is used [1].
> *This means what? That pixels with values >255 are all the same? or pixels
> like 1,034 and 2,043 are rounded?*
> URL:
> http://lists.osgeo.org/pipermail/grass-user/attachments/20101021/73c0a49a/attachment-0001.html
> Message: 7
> Date: Thu, 21 Oct 2010 13:09:09 +0200
> From: Markus Metz <markus.metz.giswork at googlemail.com>
> To: Kim Besson <kimbesson1981 at gmail.com>
> Message-ID:
>        <AANLkTimEJ7_NwuE=n50Jabs3Gw+p-MDOA7MCH_imn6Xw at mail.gmail.com<n50Jabs3Gw%2Bp-MDOA7MCH_imn6Xw at mail.gmail.com>
> Content-Type: text/plain; charset=ISO-8859-1
> >>> function
> I think the representable range of CELL is -2,147,483,647 to
> 2,147,483,647. Anything beyond the range of CELL will be transformed
> (by the system, not by GRASS) to fall within the range.
> > or pixels like 1,034 and 2,043 are rounded?
> Truncated, not rounded, e.g.
> 1.034 -> 1
> 1.9 -> 1
> 2.1 -> 2
> -1.9 -> -1
> Markus M
> Message: 8
> Date: Thu, 21 Oct 2010 13:57:45 +0200
> From: Micha Silver <micha at arava.co.il>
> Subject: Re: Fwd: [GRASS-user] v.in.ascii
> To: Luca Cinquepalmi <cinquepalmi at planetek.it>
> Cc: grass-user at lists.osgeo.org
> Message-ID: <4CC02AB9.4000302 at arava.co.il>
> Content-Type: text/plain; charset="us-ascii"
> URL:
> http://lists.osgeo.org/pipermail/grass-user/attachments/20101021/b8231f27/attachment.html
> End of grass-user Digest, Vol 54, Issue 46
Dr. Duccio Rocchini, PhD
Edmund Mach Foundation
IASMA Research and Innovation Centre
Environment and Natural Resources Area
GIS and Remote Sensing Unit
Via Mach 1, 38010 San Michele all'Adige (TN) - Italy
Phone +39 0461 615 570
duccio.rocchini at iasma.it
skype: duccio.rocchini
web page: http://gis.fem-environment.eu/rocchini/
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20101021/d9ad2e9c/attachment.html
