[GRASS-user] Change database type
Micha Silver
micha at arava.co.il
Thu Oct 21 16:38:01 EDT 2010
On 10/21/2010 07:23 PM, Pablo Carreira wrote:
> Hi,
> I have many vectors with tables and now I want to change my database
> from sqlite to pgsql.
> I ran db.connect. And now I need to copy all the tables from sqlite to
> pgsql.
> Is there an easy way to do that?
Once you've set the database connection params, then g.copy will create
a new vector with the attributes pushed into the new database. So you
could loop thru all vectors something like:
for v in `g.mlist vect`; do
g.rename vect=$v,$v_sqlite # rename to temporary name
g.copy vect=$v_sqlite,$v # copy back to original name, but
pgsql tables will be created
done
If everything looks good, then you can remove all the vectors *_sqlite:
g.remove vect=`g.mlist vect sep=, pat="*_sqlite"`
> Thanks.
> Pablo Torres Carreira
> This mail was received via Mail-SeCure System.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Micha Silver
Arava Development Co. +972-52-3665918
http://surfaces.co.il
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20101021/cbe69149/attachment.html
