[GRASS-user] Check if a raster map has any valid pixel
Kim Besson
kimbesson1981 at gmail.com
Tue Oct 26 03:47:53 EDT 2010
Thank Glynn. But how can I retrieve min and max using a Python Script?
2010/10/25 Glynn Clements <glynn at gclements.plus.com>
> Kim Besson wrote:
> > I have a python script where I need to check if an input raster map has
> any
> > valid pixel (at least one pixel that is not null). How can I check this
> > (easy and quick way?) in order to be integrated in my Script?
> Check the range:
> $ r.mapcalc --o 'foo = null()'
> $ r.info -r foo
> min=NULL
> max=NULL
> The range can only have min=max=NULL if there are no non-null cells.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20101026/834dfa70/attachment.html
