[GRASS-user] Building 6.5: SQLite3 Error
Markus Metz markus.metz.giswork at googlemail.com
Thu Oct 28 02:26:04 EDT 2010
Rich Shepard wrote:
>  I've not hit this error when I last built -6.5, and the sqlite libs are in
> /usr/lib/.
OK.
> I think I need to refine the location in the configure file, but
> want to check here first.
>  The error is:
> checking for location of SQLite library... checking for sqlite3_open in
> -lsqlite3... no
> checking for sqlite3_open in -lsqlite3... no
> configure: error: *** Unable to locate SQLite library.
> and the configure command includes:
> --with-postgres --with-sqlite --with-sqlite-libs=/usr/sqlite
Not OK, should be --with-sqlite-libs=/usr/lib if the sqlite libs are in /usr/lib
Markus M
 --with-cairo
> --with-freetype --with-cxx \
> --with-geos=usr/bin/geos-config --with-gdal=/usr/bin/gdal-config \
> --with-python=/usr/bin/python-config --with-wxwidgets=/usr/bin/wx-config \
> --with-includes=/usr/include/ --with-libs=/usr/lib/ --enable-largefile
>  I'm not seeing my error here. Please point it out to me.
> Rich
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
