[GRASS-user] Lot of python warnings GRASS SVN 6.4.1
Chethan S
chethanuniversal at gmail.com
Sun Oct 31 04:17:44 EDT 2010
Greetings!
I use GRASS 6.4.1 svn release version. Today I updated it using 'svn up'
command and ran subsequent processes up to make install. Everything went
smoothly.
But now when I start grass, by typing grass64 in terminal following warnings
appear:
Cleaning up temporary files ...
Starting GRASS ...
`menu_proxy_module_load': python: undefined symbol: menu_proxy_module_load
(python:10421): Gtk-WARNING **: Failed to load type module: (null)
(python:10421): GLib-GObject-WARNING **: invalid (NULL) pointer instance
(python:10421): GLib-GObject-CRITICAL **: g_signal_connect_data: assertion
`G_TYPE_CHECK_INSTANCE (instance)' failed
After I select the location and mapset still more warnings appear and the
prompt to enter commands does not appear in terminal. These are the
warnings that appear:
(python:11011): Gtk-WARNING **: Failed to load type module: (null)
(python:11011): GLib-GObject-WARNING **: invalid (NULL) pointer instance
(python:11011): GLib-GObject-CRITICAL **: g_signal_connect_data: assertion
*lot of lines in between*
What may be the reason for this? I use ubuntu lucid lynx which I update
regularly.
Thanks and regards,
Chethan S.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20101031/4cc8166f/attachment.html
