[GRASS-user] g.extension not working
Markus Neteler
neteler at osgeo.org
Thu Sep 2 15:30:59 EDT 2010
On Thu, Sep 2, 2010 at 9:08 PM, Glynn Clements <glynn at gclements.plus.com> wrote:
> Hamish wrote:...
>> (does g.extension work at all with standalone WinGrass?)
To my knowledge only the Python version in GRASS 7.
>> addons should really be installed to $GRASS_ADDON_PATH, right? not $GISBASE
>> (typically that will be read-only if GRASS came from a package; GISBASE is
>> the default for prefix= currently).
> On a system where GRASS itself has been installed from a "package"
> (RPM or similar), the installation probably shouldn't be modified
> other than via the OS' own administration tools.
Right - I replace my sudo suggestion with $GRASS_ADDON_PATH magic :)
Markus
