[GRASS-user] Adding options to grass.run_command
    Martin Landa
    landa.martin at gmail.com
    Fri Sep  3 12:01:17 EDT 2010
2010/9/3 Hanlie Pretorius <hanlie.pretorius at gmail.com>:
> grass.run_command("r.in.xyz", input=directory+'/'+file,
> output=rainraster, fs=',', x=2, y=1)
better `input = os.path.join(directory, file)`
> but this doesn't:
> grass.run_command("r.in.xyz", --overwrite, input=directory+'/'+file,
> neither does this:
> grass.run_command("r.in.xyz --overwrite", input=directory+'/'+file,
should be `overwrite = True` instead `--overwrite`
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
