[GRASS-user] Shortest Distance v.net.path
jfk02
kaplanj at gmail.com
Fri Sep 3 16:46:51 EDT 2010
Hello,
I am working with v.net.path in Grass 6.4.0RC7. I am attempting to get the
shortest distance between a point and numerous other points along a network
of streets. I have point A going to 112 different point Bs. I created a text
file that looks like this and is loaded into GRASS as the file containing
the start and end points:
0 747212.685926 4720037.13823 746483.659225 4716904.53527
1 747212.685926 4720037.13823 746500.601921 4716933.7664
2 747212.685926 4720037.13823 746511.948724 4716964.86195
3 747212.685926 4720037.13823 746520.848479 4716995.63643
4 747212.685926 4720037.13823 746516.776154 4717023.48178
5 747212.685926 4720037.13823 746546.774411 4717037.56583
6 747212.685926 4720037.13823 746573.881945 4717057.02371
etc...
It seems like the path works for some start and finish point combonations,
but for others it does not and it simply draws a straight line between point
A and point B (see image below). I am hoping someone might be able to tell
me why this may be happening and how I can stop this from happening. The
coordinate system I am using is in US feet and I am using a Maximum Distance
to Network of "1" because all of the points should fall essentially right on
the line. Thank you very much for any help you can lend.
http://osgeo-org.1803224.n2.nabble.com/file/n5496931/Grass_Window.jpg
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Shortest-Distance-v-net-path-tp5496931p5496931.html
Sent from the Grass - Users mailing list archive at Nabble.com.
