[GRASS-user] Importing a Scanned Map
    kapo coulibaly
    kmcoulib at gmail.com
    Sun Sep  5 13:21:56 EDT 2010
I believe the wld is a world file, all it has is the coordinate but not the
projection infos (not sure about the xml file though). I would suggest you
create a dummy GRASS mapset with the projection your tif file was
georeferenced at, then use r.proj to import it in your intended location.
let me know if I missed the point you were trying to make.
On Sun, Sep 5, 2010 at 11:20 AM, David Kindem <dkindem at gmail.com> wrote:
> The file is a .tif file with two associated files, a .wld and a
> tif.aux.xml.
> Dave
> David Kindem
> On Sep 5, 2010, at 11:01 AM, kapo coulibaly wrote:
> What format is the map in?
> On Sun, Sep 5, 2010 at 10:50 AM, David Kindem <dkindem at gmail.com> wrote:
>>  Hello,
>> I am trying to import a raster map using r.in.gdal.  The map was
>> previously georeferenced in Q-GIS.  When I run r.in.gdal, I receive the
>> message that the projection of dataset does not appear to match current
>> location.
>> I used the location parameter to create a new location for the scanned
>> map.  When I attempted to re-project the map from my new location into my
>> intended GRASS location, I received the following error:
>> Unable to get projection info of input map.
>> Looking at the projection information, the projection for the scanned map
>> and for my GRASS location match, with the exception of the cellhd.proj
>> parameter.  The scanned map's cellhd.proj = 0 (unreferenced/unknown).
>> I'm not familiar with the function of the cellhd.proj.  Could someone shed
>> some light on how I might be able to resolve the issue?
>> Thanks,
>> Dave
>>  David Kindem
>> Grand Haven, MI
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100905/e70d13be/attachment.html
