[GRASS-user] GRASS starting problem - Mac
William Kyngesburye woklist at kyngchaos.com
Tue Sep 7 12:00:48 EDT 2010
Looks like your system got corrupted.  Maybe an interrupted security update, though recent updates haven't touched QD.framework (according to timestamps on my Macs).  Or some other poorly-made installer or updater messed around in the system.  Are you having problems with any other applications?
If you use Time Machine, I'd try restoring a previous state.  Otherwise you may have to reinstall the system.
Just to be sure - you did install the correct GRASS package for your system?  Leopard/Snow Leopard - 10.5/10.6.
On Sep 7, 2010, at 9:51 AM, schorschli wrote:
> Hi,
> After a Mac-security-update I can't start GRASS anymore.
> I keep geting the same error:
> Dyld Error Message:
>  Library not loaded:
> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
>  Referenced from:
> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
>  Reason: no suitable image found.  Did find:
> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD:
> unknown file type, first eight bytes: 0x00 0x00 0x00 0x00 0x00 0x00 0x00
> 0x00
> I allready tried to reinstalled GRASS (using the newest installer from
> http://www.kyngchaos.com/software/grass)
> Any idea what could be wrong and how to fix this?
> Thanks,
> Schorschli
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/GRASS-starting-problem-Mac-tp5506724p5506724.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
"We are at war with them. Neither in hatred nor revenge and with no particular pleasure I shall kill every ___ I can until the war is over. That is my duty."
"Don't you even hate 'em?"
"What good would it do if I did? If all the many millions of people of the allied nations devoted an entire year exclusively to hating the ____ it wouldn't kill one ___ nor shorten the war one day."
<Ha, ha> "And it might give 'em all stomach ulcers."
- Tarzan, on war
