[GRASS-user] wx.class
Leonardo Hardtke
leohardtke at gmail.com
Wed Sep 8 18:18:09 EDT 2010
I tried to use it, but....
GRASS 6.4.0RC6 (Spearfish):~ > ./wx.class.py
./wx.class.py: line 19: !
@package wx.class.py
@brief Interface implementation of i.class module without Xterm.
Many thanks to Markus Neteler for his help which allowed me to
know about i.class and its usage.
Classes:
- IClass
- BufferedWindow2
- IClassApp
(C) 2006-2010 by the GRASS Development Team
This program is free software under the GNU General Public
License (>=v2). Read the file COPYING that comes with GRASS
for details.
@author Mohammed Rashad K.M <rashadkm [at] gmail [dot] com>
: command not found
import: unable to grab mouse `': Resource temporarily unavailable @
xwindow.c/XSelectWindow/8993.
./wx.class.py: line 28: syntax error near unexpected token `('
./wx.class.py: line 28: `gbase = os.getenv("GISBASE") '
any idea?
Leonardo A. Hardtke
On 09/08/2010 06:34 PM, Mohammed Rashad wrote:
> Hi all,
> I had just created a wx version of i.class module which generates
> spectral signatures for an image by allowing the user to outline
> regions of interest. The resulting signature file can be used as input
> for i.maxlik or as a seed signature file for i.cluster.
> Actual i.class module requires Xterm and work only in systems having
> Xserver installed. I created python version of i.class which works on
> all platform. Now windows users can use i.class module.
> Currently development is in beta stage. wx.class is tested and works
> only for NC dataset available from grassbook.org
> <http://grassbook.org> site.
> It uses wxpython paintDC to draw histograms which must be changed to
> use python-matplotlib for drawing smooth histograms as the output
> needed to be.
> I dont want to add a new dependency to grass as other developers but I
> am forced to do :(
> current wx.class doesn't need any other dependencies. The needs some
> cleanup but as I am busy with some other works related to GRASS I
> don't have much time to spend on cleaning up the code. But within a
> month or to you can have the fully functional wx.class.
> Now I am hosting to GRASS-Addons repo because the code needs
> testing...(although needs some cleanup)
> A README is included with source which shows how to use the module.
> But wx.class is made to be user-friendly.
> Any comments or suggestions are really welcomed :)
> Rashad
> grass-user mailing list
> grass-user en lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-user
------------ próxima parte ------------
Se ha borrado un adjunto en formato HTML...
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100908/82c8fa53/attachment.html
