[GRASS-user] Error with g.region compiling on Windows
Ned Horning
horning at amnh.org
Thu Sep 9 09:14:20 EDT 2010
/Hi - I am trying to compile the weekly snapshot 2010-09-04 on Windows
XP so that I can access the r.univar.zonal addon. I get a message that
there is an error with g.region. I tried "make" in the g.region
directory and here are the errors I got:
$ make
gcc
-I/osgeo4w/usr/src/grass-6.4.svn_src_snapshot_2010_09_04/dist.i686-pc-mingw32/include
-I/c/OSGeo4W/apps/gdal-16/include -I/c/OSGeo4W/include -g -O2
-I/c/OSGeo4W/include -DPACKAGE=\""grassmods"\" -I/c/OSGeo4W/include
-o OBJ.i686-pc-mingw32/printwindow.o -c printwindow.c
In file included from c:/OSGeo4W/include/projects.h:324,
from printwindow.c:3:
c:/OSGeo4W/include/proj_api.h:61: error: syntax error before '*' token
c:/OSGeo4W/include/proj_api.h:61: warning: data definition has no type
or storage class
c:/OSGeo4W/include/proj_api.h:82: error: syntax error before "const"
c:/OSGeo4W/include/proj_api.h:94: error: syntax error before "int"
c:/OSGeo4W/include/proj_api.h:95: error: syntax error before "const"
c:/OSGeo4W/include/proj_api.h:107: error: syntax error before
"pj_get_default_ctx"
c:/OSGeo4W/include/proj_api.h:107: warning: data definition has no type
or storage class
c:/OSGeo4W/include/proj_api.h:108: error: syntax error before "pj_get_ctx"
c:/OSGeo4W/include/proj_api.h:108: warning: data definition has no type
or storage class
c:/OSGeo4W/include/proj_api.h:109: error: syntax error before "projCtx"
c:/OSGeo4W/include/proj_api.h:110: error: syntax error before
"pj_ctx_alloc"
c:/OSGeo4W/include/proj_api.h:110: warning: data definition has no type
or storage class
c:/OSGeo4W/include/proj_api.h:111: warning: parameter names (without
types) in function declaration
c:/OSGeo4W/include/proj_api.h:112: warning: parameter names (without
c:/OSGeo4W/include/proj_api.h:113: error: syntax error before "int"
c:/OSGeo4W/include/proj_api.h:114: error: syntax error before "int"
c:/OSGeo4W/include/proj_api.h:115: error: syntax error before "void"
c:/OSGeo4W/include/proj_api.h:115: error: syntax error before ')' token
c:/OSGeo4W/include/proj_api.h:116: error: syntax error before "void"
c:/OSGeo4W/include/proj_api.h:117: warning: parameter names (without
c:/OSGeo4W/include/proj_api.h:119: error: syntax error before "ctx"
make: *** [OBJ.i686-pc-mingw32/printwindow.o] Error 1
Does this look like an error with g.region or a user problem? I am not
experienced with MinGW and am probably in over my head but I've been
following the excellent instructions provided on the CompileOnWindows
Wiki page to install the snapshot version of GRASS.
The reason I'm doing all this is to have access to the r.univar.zonal
addon. Is there an easier way to access this addon when using Windows?
I'm preparing for a workshop and would like to have this capability for
an object based image classification exercise and I have to use Windows
XP computers.
Any help will be appreciated.
All the best,
Ned
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100909/bb446483/attachment-0001.html
