[GRASS-user] Estimating Albedo from Landsat
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Wed Sep 15 09:14:40 EDT 2010
Nikos wrote:
> > ... I realised that I don't really have the "correct" metadata file for
> > the scene I was given. The "meta" file available at Glovis is not really
> > the complete set of meta-information (is my guess -- missing
> > "sat_zenith=" value for example).
Hamish wrote:
> fwiw with Landsat-7 downloads from GloVis I get files like
> L7*_MTL.txt which works with the i.landsat.toar metfile= option, it
> includes SUN_ELEVATION and SUN_AZIMUTH but nothing obvious about zenith
> that I can see.
Check that out (got some metadata files finally -- no ".met" file though) --
just a part of one of the ".lea" files, i.e. the lea_01.txt:
------- Map proj. ancillary rec. number 1 -------
 record sequence number                  = 3
 1-st record subtype code                = 36
 record type code                        = 36
 2-nd subtype code                       = 18
 3-rd subtype code                       = 9
 length of this record                   = 4320
 input line nom. number of scene pixel   =             7452
 input image nom. number of scene lines  =             6884
 nominal scale of input inter-pixel...   =       30.0000000
 nominal scale of input inter-line...    =       30.0000000
 image skew at scene centre              =        2.9918563
 UTM datum and zone number for input...  = GRS80         34
 nom. WRS northing of centre in metres   =        0.0000000
 nom. WRS easting of centre in metres    =        0.0000000
 northing of input image centre in metres=  4309451.5000000
 easting of input image centre in metres =   723735.5625000
 vert. offset of scene centre to WRS...  =        0.0000000
 horiz. offset of scene centre to WRS... =        0.0000000
 orient. of input image centre in degrees=       -8.8923416
 blanks                                  =
 num. of pixels per line of proc. image  =             6336
 num. of lines per line of proc. image   =             6884
 scale of proc. inter-pix. distance...   =       30.0000000
 scale of proc. inter-line distance...   =       30.0000000
 UTM zone number for processed image     =               34
 line number in proc. image at WRS...    =     3442.0000000
 pixel number in proc. image at WRS...   =     3726.0000000
 orientation of proc. image centre...    =       -8.8923416
 nomimal satellite orbital inclination   =       98.1999969
 nomimal ascending node                  =      103.0374985
 nomimal altitude in metres              =   712278.3125000
 nom. ground speed in metres per second  =     6746.4267578
 satellite heading in degrees            =       10.5169640
 spare                                   =
 cross-track field of view in degrees    =       15.3900003
 sensor scan rate in scans per second    =       13.9934511
 sensor active sampli. rate in samples...=   104047.4453125
 sun elevation angle at WRS centre...    =       52.4986238
 sun azimuth angle at WRS centre...      =      142.9811328
 top left latitude                       =       39.8559723
 top left longitude                      =       22.3088074
 top right latitude                      =       39.7971458
 top right longitude                     =       24.9181290
 bottom left latitude                    =       37.9956665
 bottom left longitude                   =       22.2750587
 bottom right latitude                   =       37.9405975
 bottom right longitude                  =       24.8173637
 first ten zero fill                     =
------- Radiom. ancillary rec. number 1 (total 1) -------
 record sequence number                  = 4
 1-st record subtype code                = 63
 band number                             =    1
 lower radiance limit                    =  -15
 upper radiance limit                    = 1521
 blanks                                  =
 offset coefficient                      =    -1.5000000000e+00
 gain coefficient                        =     6.0235294118e-01
radiance to reflectance conv. factor    =    2.0569763e-03
Is "satellite heading in degrees = 10.5169640" the "sat_zenith" value ?
> looking in the source code, landsat_met.c (which parses the metadata file)
> isn't looking for satellite zenith- it only comes from the command line,
> and in landsat.c it seems that only the DOS2b, DOS3, and DOS4 correction
> methods actually use it. So for uncorrected method (which I guess is the
> appropriate one if the task is cloud detection??) ...
I think this is the appropriate way to go for "acca"
> ...that variable doesn't matter.
ok.
# so, here it goes... seems to run fine
i.landsat.toar band_prefix=landsat_postfire_east_sterea_ellas
method=uncorrected sensor=5 date=2007-09-05 solar_elevation=52.4986238
product_date=2007-09-05
> > the output values (even if the sat_zenith value I used is
> > non-sense) seem to be as expected for radiance/reflectance values
> good.
> > (e.g. band 1,
> > min=-0.00308741863579021, max=0.39202091888652) .
> I think this already got answered a couple of days ago, but is the
> reflectance on a scale from 0.0-1.0 (0-100%)?
> and what are the W/m^2-like units for radiance used for the output maps?
# hmmm...
r.info landsat_postfire_east_sterea_ellas.toar.6 -r
min=203.36601783578
max=319.083636050686
No way the min value is true ( 203 K = -70.15 C -- irrational for Greece - for
the moment! -)
The max value (319 K = 45.85 C) seems to fit for Greece but not for September!
Maybe for July/August.
> > Is the following the problem (you expect-ed)? I see strange
> > characters, e.g.:
> >  BAND 1  (code 1)
> >    calibrated digital number (DN): 1.0 to 255.0
> >    calibration constants (L): -1.520 to 193.000
> >    at-sensor radiance = 0.76583 � DN + -2.28583
> >    mean solar exoatmospheric irradiance (ESUN): 1983.000
> >    at-sensor reflectance = radiance / 492.32067
> >  BAND 2  (code 2)
> >    calibration constants (L): -2.840 to 365.000
> >    at-sensor radiance = 1.44819 � DN + -4.28819
> >    mean solar exoatmospheric irradiance (ESUN): 1796.000
> >    at-sensor reflectance = radiance / 445.89406
> no, that is something else, it's a non-ASCII char in the fprintf()
> string. Maybe it will show up in the email: it's the dot multiplier "·".
Yep, it shows in the e-mail  and I now understand that I was to fast "reading"
those lines before.
> for me in "less main.c" it shows up as <B7>, in nedit and vi I see the dot.
> I guess that should be %c + the code for it, or just "*" ?
or simply "x" ?
> .. displaying it will be terminal and locale dependent ..
