[GRASS-user] Re: QGIS GRASS plugin shadedrelief issue
nunosousa84 nuno_sousa_1984 at hotmail.com
Sun Sep 19 10:55:33 EDT 2010
Thank you Sab. I have tried to use the shaded relief plugin but it gives the
following error:
"An error has occured while executing Python code:
  File "/home/nmc/.qgis//python/plugins/shadedrelief/ShadedReliefDialog.py",
line 82, in accept
    myEngine.run()
  File "/home/nmc/.qgis//python/plugins/shadedrelief/ShadedReliefEngine.py",
line 118, in run
    self.outFileParam=os.path.normpath(str(self.outFileParam))
UnicodeEncodeError: 'ascii' codec can't encode character u'\xc1' in position
10: ordinal not in range(128)
Python version:
2.6.5 (r265:79063, Apr 16 2010, 13:28:26)
[GCC 4.4.3]
Python path: ['/usr/share/qgis/python', '/home/nmc/.qgis//python',
'/home/nmc/.qgis//python/plugins', '/usr/share/qgis/python/plugins',
'/usr/lib/python2.6', '/usr/lib/python2.6/plat-linux2',
'/usr/lib/python2.6/lib-tk', '/usr/lib/python2.6/lib-old',
'/usr/lib/python2.6/lib-dynload', '/usr/lib/python2.6/dist-packages',
'/usr/lib/python2.6/dist-packages/PIL',
'/usr/lib/python2.6/dist-packages/gst-0.10', '/usr/lib/pymodules/python2.6',
'/usr/lib/python2.6/dist-packages/gtk-2.0',
'/usr/lib/pymodules/python2.6/gtk-2.0',
'/usr/local/lib/python2.6/dist-packages',
'/usr/share/qgis/python/plugins/fTools/tools']"
Any help interpret this?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/QGIS-GRASS-plugin-shadedrelief-issue-tp5547443p5547792.html
Sent from the Grass - Users mailing list archive at Nabble.com.
