[GRASS-user] converting lines to polygons
Micha Silver
micha at arava.co.il
Thu Sep 23 10:01:36 EDT 2010
On 09/22/2010 02:40 PM, Bryan Keith wrote:
>> On 09/22/2010 12:45 AM, Bryan Keith wrote:
>>> Hello,
>>> I'm using these commands:
>>> v.clean input=test_ln output=testclean_ln tool=snap,bpol thresh=0.2,0
>>> v.type input=testclean_ln output=testclean_bnd type=line,boundary
>>> v.centroids input=testclean_bnd output=testclean_py
>>> trying to convert a bunch of lines to 5 polygons. I've tried lots of
>>> variations of v.clean including many snap thresholds, but I can only get
>>> 3
>>> polygons. Is there something I'm doing wrong?
>> If it's only two missing, then just manually add centroids to those two
>> areas that are not yet polygons. (using v.digit)
> Well, it's two in this simple little example clipped from a larger file,
> and I have lots of files to process so I'm looking for an automated
> process.
Can you figure out why other areas were not closed? Maybe you need a
larger threshold value?
By opening the vector with v.digit you'll see by the color coding of the
nodes which are part of closed boundaries (dark green) and which are on
a "broken" boundary (red).
You'll also see quickly where you have centroids inside correct
boundaries, and where you're missing them.
> Bryan
>>> Check out the line and polygons here:
>>> http://www.ideotrope.org/~bryan/lines.png
>>> http://www.ideotrope.org/~bryan/polygons.png
>>> Bryan
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>>> This mail was received via Mail-SeCure System.
>> Micha Silver
>> Arava Development Co. +972-52-3665918
>> http://surfaces.co.il
Micha Silver
