[GRASS-user] First time trying to install add on g.extension
(r.stream.order)
Helmut Kudrnovsky
hellik at web.de
Sat Sep 25 05:19:32 EDT 2010
>> I have looked through many posts and help files to no avail, if
>> anyone can tell me what additional steps/programs/plugins are
> >required to install addons I would really appreciate the help.
>see [http://subversion.apache.org]
some time ago I've opened a ticket in osgeo4w to include svn into the stack
>note g.extension is rather new and untested compared the rest of
>the software, especially on Windows. Besides svn for building C
>modules, you will need a C compiler which doesn't ship with the
>GRASS installer.
a C compiler is shiped with the Wingrass-installer, because all of the osgeo4w-build-
environment is included in the WinGrass-installer.
see output from the msys-rxvt-command-line of WinGrass64-release:
Cleaning up temporary files ...
Starting GRASS ...
WARNUNG: Attention!
WARNUNG: Locking is not supported on Windows!
__________ ___ __________ _______________
/ ____/ __ \/ | / ___/ ___/ / ____/ _/ ___/
/ / __/ /_/ / /| | \__ \\_ \ / / __ / / \__ \
/ /_/ / _, _/ ___ |___/ /__/ / / /_/ // / ___/ /
\____/_/ |_/_/ |_/____/____/ \____/___//____/
Welcome to GRASS 6.4.0 (2010)
GRASS homepage: http://grass.osgeo.org/
This version running thru: Bourne Shell (/bin/sh)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
If required, restart the GUI with: g.gui wxpython
When ready to quit enter: exit
GRASS 6.4> gcc --help
Usage: gcc.exe [options] file...
Options:
-pass-exit-codes Exit with highest error code from a phase
--help Display this information
--target-help Display target specific command line options
(Use '-v --help' to display command line options of sub-processes)
-dumpspecs Display all of the built in spec strings
-dumpversion Display the version of the compiler
-dumpmachine Display the compiler's target processor
-print-search-dirs Display the directories in the compiler's search pat h
-print-libgcc-file-name Display the name of the compiler's companion library
-print-file-name=<lib> Display the full path to library <lib>
-print-prog-name=<prog> Display the full path to compiler component <prog>
-print-multi-directory Display the root directory for versions of libgcc
-print-multi-lib Display the mapping between command line options and
multiple library search directories
-print-multi-os-directory Display the relative path to OS libraries
-Wa,<options> Pass comma-separated <options> on to the assembler
-Wp,<options> Pass comma-separated <options> on to the preprocesso r
-Wl,<options> Pass comma-separated <options> on to the linker
-Xassembler <arg> Pass <arg> on to the assembler
-Xpreprocessor <arg> Pass <arg> on to the preprocessor
-Xlinker <arg> Pass <arg> on to the linker
-save-temps Do not delete intermediate files
-pipe Use pipes rather than intermediate files
-time Time the execution of each subprocess
-specs=<file> Override built-in specs with the contents of <file>
-std=<standard> Assume that the input sources are for <standard>
-B <directory> Add <directory> to the compiler's search paths
-b <machine> Run gcc for target <machine>, if installed
-V <version> Run gcc version number <version>, if installed
-v Display the programs invoked by the compiler
-### Like -v but options quoted and commands not executed
-E Preprocess only; do not compile, assemble or link
-S Compile only; do not assemble or link
-c Compile and assemble, but do not link
-o <file> Place the output into <file>
-x <language> Specify the language of the following input files
Permissible languages include: c c++ assembler none
'none' means revert to the default behavior of
guessing the language based on the file's extension
Options starting with -g, -f, -m, -O, -W, or --param are automatically
passed on to the various sub-processes invoked by gcc.exe. In order to pass
other options on to these processes the -W<letter> options must be used.
For bug reporting instructions, please see:
<URL:http://www.mingw.org/bugs.shtml>.
GRASS 6.4>
best regards
Helmut
___________________________________________________________
GRATIS: Spider-Man 1-3 sowie 300 weitere Videos!
Jetzt kostenlose Movie-FLAT freischalten! http://movieflat.web.de
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20100925/b0069206/smime.bin
