[GRASS-user] Estimating Albedo from Landsat
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Sat Sep 25 19:43:04 EDT 2010
Nikos:
> Downloaded:
> - extra: LT50160351988258XXX03 (includes visible clouds - maybe good for
> testing?)
# import landsat bands in wgs84, utm, zone 17
# r.proj to nc_spm_08/landsat
# set region
g.region rast=lsat5_1988.1 -p
projection: 99 (Lambert Conformal Conic)
zone: 0
datum: nad83
ellipsoid: a=6378137 es=0.006694380022900787
north: 361770
south: 144750
west: 463950
east: 709530
nsres: 30
ewres: 30
rows: 7234
cols: 8186
cells: 59217524
# rgb colors for 742
i.landsat.rgb r=lsat5_1988.2 g=lsat5_1988.4 b=lsat5_1988.7 strength=96
d.rgb r=lsat5_1988.2 g=lsat5_1988.4 b=lsat5_1988.7 # obvious clouds
# toar
i.landsat.toar band_prefix=lsat5_1988 method=uncorrected sensor=5
product_date=1988-09-14 date=1988-09-14 solar_elevation=48.6773844
# acca
i.landsat.acca -5f2 band_prefix=lsat5_1988.toar output=lsat5_1988.toar.acca
# how many cats?
r.info lsat5_1988.toar.acca -r
min=6
max=9
# draw only "acca" cat=6
d.erase black
d.rast lsat5_1988.toar.acca cat=6 -o
In the "acca" result:
- clouds are detected (cat=6), not that bad(ly) I suppose. Some filtering
could push away the (rest of the) "noise".
- obvious mis-detections (commission errors) found within
- n=188310 s=168270 w=618870 e=636150 (bare ground? urban area? not sure
about the confusing land cover/class here...)
- n=219030 s=180510 w=646410 e=655740 (road)
- in the borders due to the non-identical extent of all bands (!?)
- categories 7 and 8 seem to be empty, category 9 looks very messy
Could it be that non-cloudy acquisitions are mistreated by the algorithm? I
can't clearly recognise clouds in the landsat scenes included in NC data set
(both the 1987 and the 2000 scenes).
Will (then) the algorithm work (only) with (very) cloudy data?
Nikos
