[GRASS-user] Grass-GIS 6.4 font bug in OSX
Markus Neteler
neteler at osgeo.org
Mon Sep 27 09:22:09 EDT 2010
On Sun, Sep 26, 2010 at 11:12 PM, Richard Chirgwin
<rchirgwin at ozemail.com.au> wrote:
> Hi,
> I've just install 6.4 under OSX 10.5.8, and have run into a problem.
> Reproduced in Spearfish:
> d.vect bugsites - OK
> d.vect bugsites display=attr attrcol=str1 - OK
> d.vect bugsites display=attr attrcol=str1 font='Arial Italic'
> produces this error, repeated many times:
> The process has forked and you cannot use this CoreFoundation functionality
> safely. You MUST exec().
> Break on
> __THE_PROCESS_HAS_FORKED_AND_YOU_CANNOT_USE_THIS_COREFOUNDATION_FUNCTIONALITY___YOU_MUST_EXEC__()
> to debug.
> Then the X monitor window closes.
> Any ideas?
See
http://trac.osgeo.org/grass/ticket/377
http://lists.osgeo.org/pipermail/grass-user/2009-April/050038.html
and
http://developer.apple.com/mac/library/technotes/tn2005/tn2083.html#SECDAEMONVSFRAMEWORKS
Markus
