[GRASS-user] Converting raster to polygon creates too many
polygons
razmjooeis at faunalia.co.uk
Wed Sep 29 08:24:17 EDT 2010
You might consider using -s flag to smooth the corners.
Otherwise, I can't see why it doesn't work.
R.
Sab
> Hi,
> I've created subcatchments using r.watershed and I would like to
> convert these to polygons. My result at the moment contains too many
> polygons - 194. The original raster had only 9 areas, which should all
> have been contiguous seeing that they came from r.watershed.
> Here is the sequence of commands that I use, starting with r.report
> for the information about the subcatchments raster:
> | Type of Map: raster Number of Categories: 18
> | Data Type: CELL
> | Rows: 33443
> | Columns: 33008
> | Total Cells: 1103886544
> | Projection: Transverse Mercator
> | N: -3122229.69982072 S: -3155672.30728643 Res:
> 0.99998826
> | E: -33474.90929218 W: -66483.27873573 Res: 1.00001119
> | Range of data: min = 2 max = 18
> # Set the resolution to 25m
> g.region rast=c83a_border res=25
> # Convert the subcatchment raster to vector
> r.to.vect --overwrite
> input=c83a_dem_25m_clipped_basins_100000_clipped at PERMANENT
> output=c83a_subcatchments at PERMANENT feature=area
> v.report for the resulting vector gives me 194 categories. The
> original raster had only 9 areas, which should all have been
> contiguous seeing that they come from r.watershed.
> What am I doing wrong? I want an output vector with 9 polygons
> corresponding to the original 9 areas in the subcatchment raster.
> Thanks
> Hanlie
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
