[GRASS-user] Problem with Python Scripts and grass.script
	(GRASS	6.5SVN) on Mac
    Johannes Radinger
    JRadinger at gmx.at
    Fri Apr  1 07:48:31 EDT 2011
Thank you for your answer...
strange that this script isn't working on my mac...
..does it produce an outputmap on linux?
what can be the reason why I don't get an output
on my mac with current 6.5?
/johannes
Am 30.03.2011 um 19:22 schrieb Glynn Clements:
> Johannes Radinger wrote:
>> The script I am trying is the simpliest form of a script calling just one
>> function of GRASS (e.g. mapcalc or r.thin),
>> attached you can find that script which can be applied e.g. on the spearfish
>> rasterdataset...and in my opinion it is correct and in the correct order
>> of commands as mentioned in the grass-wiki and with the correct line endings.
> FWIW, the script works fine on Linux with current 7.0.
> Glynn Clements <glynn at gclements.plus.com>
