[GRASS-user] Problem with Python Scripts and grass.script (GRASS 6.5SVN) on Mac
Sat Apr 2 18:37:47 EDT 2011
Johannes Radinger wrote:
> I tried to figure out the problem with william kyngesburye.
> the script is also working on his mac. I saved the script in the bin
> folder and ran in the GRASS terminal:
> AttributeError: 'module' object has no attribute 'mapcalc'
> What causes this AttributeError?
The grass.script module is either broken or very old (the mapcalc()
function was added in December 2008).
>From within GRASS, try the following:
	$ python
	> import grass.script as grass
	> print grass.__file__
	> print grass.__path__
