[GRASS-user] Re: grass-user Digest, Vol 60, Issue 5
vinod kumar
nani.kunithi at gmail.com
Mon Apr 4 06:09:04 EDT 2011
Hi Hamesh,
Thanks for providing the information.
I have installed "Cygwin" and still am getting the same error Displaying
that there is no such command. Can you explain more clearly what should i do
to execute this command.
Thanks,
nani.
On Sun, Apr 3, 2011 at 6:00 PM, <grass-user-request at lists.osgeo.org> wrote:
> Send grass-user mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
> http://lists.osgeo.org/mailman/listinfo/grass-user
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> grass-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of grass-user digest..."
> Today's Topics:
> 1. Re: Problem with Python Scripts and grass.script (GRASS
> 6.5SVN) on Mac (Glynn Clements)
> 2. Re: Re: r.li.setup (Hamish)
> 3. Re: Using r.buffer on image with geographic coordinates
> (Markus Metz)
> Message: 1
> Date: Sat, 2 Apr 2011 23:37:47 +0100
> From: Glynn Clements <glynn at gclements.plus.com>
> Subject: Re: [GRASS-user] Problem with Python Scripts and grass.script
> (GRASS 6.5SVN) on Mac
> To: Johannes Radinger <JRadinger at gmx.at>
> Cc: grass-user at lists.osgeo.org, Michael Barton
> <Michael.Barton at asu.edu>
> Message-ID: <19863.42299.525955.400396 at cerise.gclements.plus.com>
> Content-Type: text/plain; charset=us-ascii
> Johannes Radinger wrote:
> > I tried to figure out the problem with william kyngesburye.
> > the script is also working on his mac. I saved the script in the bin
> > folder and ran in the GRASS terminal:
> > AttributeError: 'module' object has no attribute 'mapcalc'
> > What causes this AttributeError?
> The grass.script module is either broken or very old (the mapcalc()
> function was added in December 2008).
> >From within GRASS, try the following:
> $ python
> > import grass.script as grass
> > print grass.__file__
> > print grass.__path__
> Message: 2
> Date: Sat, 2 Apr 2011 16:52:15 -0700 (PDT)
> From: Hamish <hamish_b at yahoo.com>
> Subject: Re: [GRASS-user] Re: r.li.setup
> To: grass-user at lists.osgeo.org, vinod kumar <nani.kunithi at gmail.com>
> Message-ID: <235869.98585.qm at web110005.mail.gq1.yahoo.com>
> Content-Type: text/plain; charset=iso-8859-1
> Nani wrote:
> >r.li.setup
> > How to install, Where to find it, how is it provided,
> r.li.* is not provided in WinGrass. Only on UNIX builds (Mac or
> Linux). If you want to use these modules, you may also try the
> Cygwin build of GRASS for MS Windows, or try the older r.le
> modules.
> > what is it supposed this command do.
> see http://grass.osgeo.org/grass64/manuals/html64_user/r.li.html
> Hamish
> Message: 3
> Date: Sun, 3 Apr 2011 15:07:47 +0200
> From: Markus Metz <markus.metz.giswork at googlemail.com>
> Subject: Re: [GRASS-user] Using r.buffer on image with geographic
> coordinates
> To: Ned Horning <horning at amnh.org>
> Cc: GRASS user list <grass-user at lists.osgeo.org>
> Message-ID: <BANLkTi=C5ETWZ0OH267Y3zQ3bvgrmB1kJw at mail.gmail.com>
> Content-Type: text/plain; charset=ISO-8859-1
> On Wed, Mar 30, 2011 at 1:52 PM, Ned Horning <horning at amnh.org> wrote:
> > Thanks for the help compiling with v.buffer. I think I'm running the
> correct
> > version now but the function still does not complete properly. I pasted
> the
> > last several lines from the terminal screen below. I have a feeling I ran
> > out of memory. Any ideas about what I can try next?
> Not sure if the "d.vect: free(): invalid" error means that d.vect
> caused the problem.
> You could try several things:
> - update your grass-6.5 to r45873
> - close the grass gui and other applications not really necessary
> - now try v.buffer again
> The process got killed while snapping boundaries which is rather
> memory demanding. Memory consumption for vector operations like
> snapping can be substantially reduced in grass 7, but grass 7 still
> has only the broken version of v.buffer2 (to be fixed).
> Alternatively you could use r.grow.distance on the rasterized version
> and set all values larger than the desired buffer distance to NULL
> Markus M
> > D0/0: sa: 22
> > D0/0: current: 22
> > D0/0: current = 29, last = 30, lcount = 1
> > D0/0: sa: 28
> > D0/0: current: 28
> > D0/0: current = 29, last = 34, lcount = 1
> > D0/0: sa: 28
> > D0/0: current: 28
> > Building parts of topology...
> > Building topology for vector map <testBuf>...
> > Registering primitives...
> > 1433691 primitives registered
> > 119731336 vertices registered
> > Number of nodes: 1433605
> > Number of primitives: 1433691
> > Number of points: 0
> > Number of lines: 0
> > Number of boundaries: 1433691
> > Number of centroids: 0
> > Number of areas: -
> > Number of isles: -
> > Snapping boundaries...
> > Killed
> > GRASS 6.5.svn (NHD_Test):~ >
> > GRASS 6.5.svn (NHD_Test):~ > *** glibc detected *** d.vect: free():
> invalid
> > next size (normal): 0x0000000001a77fc0 ***
> > ======= Backtrace: =========
> > /lib/libc.so.6(+0x775b6)[0x7f32f1a055b6]
> > /lib/libc.so.6(cfree+0x73)[0x7f32f1a0be83]
> > /usr/local/grass-6.5.svn/lib/libgrass_vect.6.5.svn.so
> (Vect_destroy_line_struct+0x28)[0x7f32f35be638]
> > d.vect(plot1+0xb0a)[0x40876a]
> > d.vect(main+0x1314)[0x4072d4]
> > /lib/libc.so.6(__libc_start_main+0xfd)[0x7f32f19acc4d]
> > d.vect[0x403cd9]
> > ======= Memory map: ========
> > 00400000-0040c000 r-xp 00000000 08:05 206108
> > /usr/local/grass-6.5.svn/bin/d.vect
> > 0060b000-0060c000 r--p 0000b000 08:05 206108
> > 0060c000-0060d000 rw-p 0000c000 08:05 206108
> > 01a6a000-01a8b000 rw-p 00000000 00:00 0
> > [heap]
> > 7f32e4000000-7f32e4021000 rw-p 00000000 00:00 0
> > 7f32e4021000-7f32e8000000 ---p 00000000 00:00 0
> > 7f32e8b3c000-7f32e8b48000 r-xp 00000000 08:05 531120
> > /lib/libnss_files-2.11.1.so
> > 7f32e8b48000-7f32e8d47000 ---p 0000c000 08:05 531120
> > 7f32e8d47000-7f32e8d48000 r--p 0000b000 08:05 531120
> > 7f32e8d48000-7f32e8d49000 rw-p 0000c000 08:05 531120
> > 7f32e8d49000-7f32e8d53000 r-xp 00000000 08:05 531542
> > /lib/libnss_nis-2.11.1.so
> > 7f32e8d53000-7f32e8f52000 ---p 0000a000 08:05 531542
> > 7f32e8f52000-7f32e8f53000 r--p 00009000 08:05 531542
> > 7f32e8f53000-7f32e8f54000 rw-p 0000a000 08:05 531542
> > 7f32e8f54000-7f32e8f5c000 r-xp 00000000 08:05 527981
> > /lib/libnss_compat-2.11.1.so
> > 7f32e8f5c000-7f32e915b000 ---p 00008000 08:05 527981
> > 7f32e915b000-7f32e915c000 r--p 00007000 08:05 527981
> > 7f32e915c000-7f32e915d000 rw-p 00008000 08:05 527981
> > 7f32e915d000-7f32e9160000 r-xp 00000000 08:05 523508
> > /lib/libgpg-error.so.0.4.0
> > 7f32e9160000-7f32e935f000 ---p 00003000 08:05 523508
> > 7f32e935f000-7f32e9360000 r--p 00002000 08:05 523508
> > 7f32e9360000-7f32e9361000 rw-p 00003000 08:05 523508
> > 7f32e9361000-7f32e9371000 r-xp 00000000 08:05 134688
> > /usr/lib/libtasn1.so.3.1.7
> > 7f32e9371000-7f32e9570000 ---p 00010000 08:05 134688
> > 7f32e9570000-7f32e9571000 r--p 0000f000 08:05 134688
> > 7f32e9571000-7f32e9572000 rw-p 00010000 08:05 134688
> > 7f32e9572000-7f32e958b000 r-xp 00000000 08:05 134634
> > /usr/lib/libsasl2.so.2.0.23
> > 7f32e958b000-7f32e978a000 ---p 00019000 08:05 134634
> > 7f32e978a000-7f32e978b000 r--p 00018000 08:05 134634
> > 7f32e978b000-7f32e978c000 rw-p 00019000 08:05 134634
> > 7f32e978c000-7f32e97a2000 r-xp 00000000 08:05 531562
> > /lib/libresolv-2.11.1.so
> > 7f32e97a2000-7f32e99a1000 ---p 00016000 08:05 531562
> > 7f32e99a1000-7f32e99a2000 r--p 00015000 08:05 531562
> > 7f32e99a2000-7f32e99a3000 rw-p 00016000 08:05 531562
> > 7f32e99a3000-7f32e99a5000 rw-p 00000000 00:00 0
> > 7f32e99a5000-7f32e99a7000 r-xp 00000000 08:05 523515
> > /lib/libkeyutils-1.2.so
> > 7f32e99a7000-7f32e9ba6000 ---p 00002000 08:05 523515
> > 7f32e9ba6000-7f32e9ba7000 r--p 00001000 08:05 523515
> > 7f32e9ba7000-7f32e9ba8000 rw-p 00002000 08:05 523515
> > 7f32e9ba8000-7f32e9baf000 r-xp 00000000 08:05 134268
> > /usr/lib/libkrb5support.so.0.1
> > 7f32e9baf000-7f32e9dae000 ---p 00007000 08:05 134268
> > 7f32e9dae000-7f32e9daf000 r--p 00006000 08:05 134268
> > 7f32e9daf000-7f32e9db0000 rw-p 00007000 08:05 134268
> > 7f32e9db0000-7f32e9dd4000 r-xp 00000000 08:05 132675
> > /usr/lib/libk5crypto.so.3.1
> > 7f32e9dd4000-7f32e9fd4000 ---p 00024000 08:05 132675
> > 7f32e9fd4000-7f32e9fd5000 r--p 00024000 08:05 132675
> > 7f32e9fd5000-7f32e9fd6000 rw-p 00025000 08:05 132675
> > 7f32e9fd6000-7f32e9fed000 r-xp 00000000 08:05 527976
> > /lib/libnsl-2.11.1.so
> > 7f32e9fed000-7f32ea1ec000 ---p 00017000 08:05 527976
> > 7f32ea1ec000-7f32ea1ed000 r--p 00016000 08:05 527976
> > 7f32ea1ed000-7f32ea1ee000 rw-p 00017000 08:05 527976
> > 7f32ea1ee000-7f32ea1f0000 rw-p 00000000 00:00 0
> > 7f32ea1f0000-7f32ea265000 r-xp 00000000 08:05 523504
> > /lib/libgcrypt.so.11.5.2
> > 7f32ea265000-7f32ea464000 ---p 00075000 08:05 523504
> > 7f32ea464000-7f32ea465000 r--p 00074000 08:05 523504
> > 7f32ea465000-7f32ea468000 rw-p 00075000 08:05 523504
> > 7f32ea468000-7f32ea504000 r-xp 00000000 08:05 134182
> > /usr/lib/libgnutls.so.26.14.12
> > 7f32ea504000-7f32ea703000 ---p 0009c000 08:05 134182
> > 7f32ea703000-7f32ea709000 r--p 0009b000 08:05 134182
> > 7f32ea709000-7f32ea70a000 rw-p 000a1000 08:05 134182
> > 7f32ea70a000-7f32ea717000 r-xp 00000000 08:05 132150
> > /usr/lib/liblber-2.4.so.2.5.4
> > On 03/29/2011 03:00 AM, Markus Neteler wrote:
> >> On Tue, Mar 29, 2011 at 8:27 AM, Markus Metz
> >> <markus.metz.giswork at googlemail.com> wrote:
> >>> If you ran make in the v.buffer directory and afterwards configure,
> >>> make and make install in /usr/local/src/grass6_devel, you would end up
> >>> with v.buffer2.
> >>> 1. run configure, make, but not make install in
> >>> 2. run make in the v.buffer directory, watch out for errors to make
> >>> sure it compiles all right
> >>> 3. run make install in /usr/local/src/grass6_devel, but not again
> >>> configure and/or make
> >>> 4. that should give you the original v.buffer
> >> An alternative: simply modify
> >> vector/Makefile
> >> to point to v.buffer and not v.buffer2...
> >> Markus
> End of grass-user Digest, Vol 60, Issue 5
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110404/72265568/attachment-0001.html
