SV: [GRASS-user] Vector map text legend
Martin Album Ytre-Eide
Martin.Album.Ytre-Eide at nrpa.no
Mon Apr 4 06:53:30 EDT 2011
"the way to do this is to use r.category to add category labels to each of your four raster category numbers, then use d.legends's -c flag to hide the value of the number, so only the label is displayed."
This was exactly what I was looking for. This solves many of my legend issues. Thanks a lot.
A follow up question is: Would this be a good way to deal with logarithmic values in a legend?
-I convert rasters to have logarithmic values with r.mapcal: map = log(old_map,10)
-This gives me a nice map with a nice legend. One could use r.colors -g (logarithmic scaling), but this messes up the legend - the legend is still linear- and it does not look good.
-The problem is(my way of doing things) that the category numbers are log values as well(say 1-3-5 insted of 10-1000-100000), which there is noting wrong with, it is just not that easy to read.
So, is it a good idea to add category labels to all values (or a range of values) x - 10^x ( so for 1, I add 10 and so fort) or is it a better way to do this as well?
Martin
-----Opprinnelig melding-----
Fra: Hamish [mailto:hamish_b at yahoo.com]
Sendt: 2. april 2011 08:56
Til: grass-user at lists.osgeo.org
Kopi: Martin Album Ytre-Eide
Emne: Re: [GRASS-user] Vector map text legend
Martin Album Ytre-Eide wrote:
> I am looking for a way to make a legend to some vector area maps. The
> maps contain four different types of areas and are given different
> names.
> I have made a python script running d.mon, d.vect etc. with the png
> driver producing about 14 png files, which then is used to create a
> gif file.
> A way to create a vector legend is to do v.to.rast and use the
> d.legend from the "dummy" rast -
(e.g. the v.colors script)
> however, I don't see how you can get a legend with text in this way? I
> don't think you can since raster should have numerical values. You
> could make a legend without category numbers and try to add the text
> with d.text, but I don't know if that's a good way of doing things.
d.text would work, but it's a lot of trouble to get it right.
fwiw an approach to avoid the intermediary raster step is outlined in wish #89.
> Then there is ps.map which solves this in a nice way - the problem is
> - I would like to keep the png format. I could just make the legend
> with ps.map - and add it to my png files with some image tools in
> python, but I am unsure of the result is worth the effort.
It is possible, actually I used this with html2latex's pstoimg program quite recently to add a custom legend in a journal figure created by other software, as it does such a nice job. Note there are some customizations I need to finish/clean up which make that a bit nicer to use (e.g. legend entries ordered by column before row), and the ps.output addon has made an entirely new vector legend tool.
pstoimg example:
http://grass.osgeo.org/wiki/Ps.map_scripts#Converting_PostScript_to_PNG
good luck,
Hamish
