[GRASS-user] help with v.db.update
Sharon M morrisxs09 at gmail.com
Wed Apr 6 03:23:02 EDT 2011
Richard - are you working in a win XP environment? If so which vers of WinGrass?
Thanks,
Sharon
On Wed, Apr 6, 2011 at 4:48 PM, Richard Chirgwin
<rchirgwin at ozemail.com.au> wrote:
> "I don't know" is the short answer. Hamish's suggested worked here for
> v.db.update, but when I used "like" in v.db.update, it failed with the same
> error as you saw.
> Perhaps a bug in the driver?
> Richard
> On 6/04/11 5:12 PM, Sharon M wrote:
>> Why does the DBF driver handle like when using v.db.select?
>> On Wed, Apr 6, 2011 at 4:29 PM, Richard Chirgwin
>>> On 6/04/11 4:36 PM, grass-user-request at lists.osgeo.org wrote:
>>>> Message: 9
>>>> Date: Wed, 6 Apr 2011 16:06:13 +0930
>>>> From: Sharon M<morrisxs09 at gmail.com>
>>>> Subject: [GRASS-user] help with v.db.update
>>>> To:grass-user at lists.osgeo.org
>>>> Message-ID:<BANLkTi=oHUEGstNAuinLiYAMfo5-P3RBFA at mail.gmail.com>
>>>> Content-Type: text/plain; charset=ISO-8859-1
>>>> I'm trying to update an attribute table column using v.db.update with
>>>> the DBF driver and keep getting a dbmi: Protocol error message.
>>>> Example using Spearfish
>>>> g.copy vect=fields,myfields
>>>> v.db.addcol myfields col="polynum integer"
>>>> v.db.select myfields where="label like 'V%'"
>>>> cat|label|polynum
>>>> 59|V. White#1|
>>>> v.db.update myfields col=polynum val=42 where="label like 'V%'"
>>>> ERROR: Error while executing: 'UPDATE myfields SET polynum=42 WHERE
>>>> label like V%
>>>> I've tried this on both winGrass 6.4 rc2 or winGrass 6.5 r45847 on
>>>> winXP using the wxGUI via both the v.db.update module and the wxgui
>>>> command line and get the same error issue.
>>>> What am I doing wrong? Can anyone help please?
>>>> Thanks in advance!
>>> The dbf driver doesn't handle "like". Try:
>>> v.db.update myfields column=polynum val=42 where='cat=59'
>>> and see what happens ...
>>> If you need more advanced query parameters such as "like", use a
>>> different
>>> database driver - pg or mysql.
>>> Richard
>>> If
