[GRASS-user] Re: [Qgis-user] error with r.cost
ambijat ambijat at hotmail.com
Mon Apr 11 04:11:11 EDT 2011
Hi! Markus,
I am using a mask so as to limit my operation. The only improvisation I
did was this time to run the set on Fedora14 as I have my dual boot
machine. Luckily I have now my r.cost raster built. But, before going
for that I reduced the SRTM altitude values to range between 0-255. So,
some economizing on bit size was possible.
But,
But, now I am stuck with a new thing and this is with r.walk. I am still
performing this operation on F14. But, there is a crash everytime. The
input rasters are the two one the same rescaled raster for base values
and r.cost generated raster for friction values. But, it is crashing
every time. I am not getting a headway. I need to generate a route
between two cities cross the Hindukush mountain ranges in Afghanistan.
Any, ideas to this issue. I am thinking of using r.slop.aspect raster
for friction values what do you suggest.
Thanks and regards,
Ambrish Dhaka
On 4/11/2011 1:37 AM, Markus Neteler wrote:
> Ambrish Dhaka,
> you need to check the region extent + resolution, probably
> you are exceeding the available RAM if you are having too
> many rows and columns.
> Get the information with:
> g.region -p
> or the respective menu entry.
> Markus
> On Sun, Apr 10, 2011 at 10:57 AM, ambijat<ambijat at hotmail.com>  wrote:
>> Ramon says,
>> I'm afraid I don't - but given the current situations, I'd suggest anyone
>> that could help would also be wondering which version of QGIS you were using
>> and on which operating system.
>> The Qgis version is 1.6.0 also, the result is same on GRASS (tcl/tk) 6.4
>> RC1, performed on WinXP SP3 on a core2Duo machine.
>> regards,
>> Ambrish Dhaka
> On 10/04/2011, at 13:19 , ambijat wrote:
>> Hi All,
>> I am trying to create shortest path between two raster points (converted from v.to.rast) and I use the STRM data for the input values between the two points. This is the error I get.
>> r.cost input=afg_rast at user1 output=salroute start_rast=salang at user1 max_cost=0 -k
>> G_malloc: unable to allocate 524288 bytes at setup.c:64
>> Finished with error
>> Any idea why I am getting this?
>> Thanks and regards,
>> Ambrish Dhaka
> Qgis-user mailing list
