[GRASS-user] Compilation error v.krige g.extension
    Simon Verrier
    verrierspj at gmail.com
    Mon Apr 11 13:13:29 EDT 2011
Hello everyone,
I'm trying to run v.krige since about 2 weeks on Grass 6.4 via g.extension
but
it still remains an error, 2 in fact :
g.extension extension=v.krige svnurl=
https://svn.osgeo.org/grass/grass-addons/ prefix=$GISBASE
Fetching <v.krige> from GRASS-Addons SVN (be patient)...
A    v.krige/v_krige_wxGUI.py
A    v.krige/description.html
A    v.krige/v.krige.py
A    v.krige/Makefile
A    v.krige/README
 U   v.krige
Révision 45904 extraite.
if [ ! -d /build/buildd/grass-6.4.0/dist.i686-pc-linux-gnu/scripts ]; then
mkdir -p /build/buildd/grass-6.4.0/dist.i686-pc-linux-gnu/scripts; fi
/usr/bin/install -c
v.krige.py/build/buildd/grass-6.4.0/dist.i686-pc-linux-gnu/scripts/
v.krige.py
make htmlscript scriptstrings
make[1]: entrant dans le répertoire «
/home/simon/grassdata/Laspalmas/Parcelle85/.tmp/simon-pc/4006.0/v.krige »
make
/build/buildd/grass-6.4.0/dist.i686-pc-linux-gnu/docs/html/v.krige.py.html
HTMLSRC=/build/buildd/grass-6.4.0/dist.i686-pc-linux-gnu/scripts/v.krige.py
make[2]: entrant dans le répertoire «
if [ "/build/buildd/grass-6.4.0/dist.i686-pc-linux-gnu/scripts/v.krige.py"
!= "" ] ; then
GISRC=/build/buildd/grass-6.4.0/dist.i686-pc-linux-gnu/demolocation/.grassrc64
GISBASE=/build/buildd/grass-6.4.0/dist.i686-pc-linux-gnu
PATH="/build/buildd/grass-6.4.0/dist.i686-pc-linux-gnu/bin:$PATH"
LD_LIBRARY_PATH="/build/buildd/grass-6.4.0/dist.i686-pc-linux-gnu/bin:/build/buildd/grass-6.4.0/dist.i686-pc-linux-gnu/lib:/usr/lib/grass64/lib"
LC_ALL=C fakeroot /build/buildd/grass-6.4.0/dist.i686-pc-linux-gnu/scripts/
v.krige.py --html-description < /dev/null | grep -v '</body>\|</html>' >
v.krige.py.tmp.html ; true ; fi
Compiling <v.krige>...
ERROR: G_getenv(): Variable LOCATION_NAME not set
/usr/lib/grass64/tools/mkhtml.sh v.krige.py ; mkdir -p
/build/buildd/grass-6.4.0/dist.i686-pc-linux-gnu/docs/html ;
/usr/bin/install -c  -m 644 v.krige.py.tmp.html
/build/buildd/grass-6.4.0/dist.i686-pc-linux-gnu/docs/html/v.krige.py.html ;
for file in  *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null ; if
[ $? -ne 0 ] ; then /usr/bin/install -c  -m 644 $file
/build/buildd/grass-6.4.0/dist.i686-pc-linux-gnu/docs/html ; fi done 2>
/dev/null ; true
make[2]: quittant le répertoire «
PATH=/build/buildd/grass-6.4.0/dist.i686-pc-linux-gnu/bin:$PATH
LD_LIBRARY_PATH="/build/buildd/grass-6.4.0/dist.i686-pc-linux-gnu/lib:/usr/lib/grass64/lib"
g.parser -t v.krige.py | sed s/\"/\\\\\"/g | sed 's/.*/_("&")/' >
/usr/lib/grass64/locale/scriptstrings/v.krige.py_to_translate.c ; true
make[1]: quittant le répertoire «
make mancmd
make /build/buildd/grass-6.4.0/dist.i686-pc-linux-gnu/man/man1/v.krige.py.1
MANSRC=/build/buildd/grass-6.4.0/dist.i686-pc-linux-gnu/docs/html/v.krige.py.html
mkdir -p /build/buildd/grass-6.4.0/dist.i686-pc-linux-gnu/man/man1
GRASS_PERL=/usr/bin/perl VERSION_NUMBER=6.4.0 sh
/build/buildd/grass-6.4.0/tools/g.html2man/g.html2man
/build/buildd/grass-6.4.0/dist.i686-pc-linux-gnu/man/man1/v.krige.py.1 1
sh: Can't open
make[2]: *** [/build/buildd/grass-6.4.0/dist.i686-pc-linux-
gnu/man/man1/v.krige.py.1] Erreur 127
make[1]: *** [mancmd] Erreur 2
make: *** [/build/buildd/grass-6.4.0/dist.i686-pc-linux-
gnu/scripts/v.krige.py] Erreur 2
ERROR: Compilation failed, sorry. Please check above error messages.
If anyone got some clues to fix these problems, it will be awsome !
Thanks a lot.
Simon
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110411/fdc75044/attachment.html
