[GRASS-user] g.extension unable to install landsat processing
	addons in AMD64 Ubuntu
    Markus Neteler
    neteler at osgeo.org
    Tue Apr 12 15:27:34 EDT 2011
On Tue, Apr 12, 2011 at 5:14 PM, Juan Benavides Duque <jbenavid at siu.edu> wrote:
> I'm trying to donwload the addons for landsat processing in running Grass
> 6.4 under Ubuntu maverick (10.10) for an AMD64.
> When I tried to get the files from the repositories and install them I get
> the following error. I have tried the suggestions in similar treads but they
> haven't solve my problem.
> If anybody could point me in the right direction to have this processing
> tools on my machine I'll appreciate it. I have grass-dev installed already.
> Please be aware that I'm not an expert on computer science.
> here is the code output after the "g.extension i.landsat.toar" instruction
> GRASS 6.4.0 (LANDSAT2):~ > g.extension i.landsat.toar
> Fetching <i.landsat.toar> from GRASS-Addons SVN (be patient)...
> A    i.landsat.toar/landsat_set.c
> A    i.landsat.toar/local_proto.h
> A    i.landsat.toar/main.c
> A    i.landsat.toar/description.html
> A    i.landsat.toar/landsat.c
> A    i.landsat.toar/earth_sun.c
> A    i.landsat.toar/landsat.h
> A    i.landsat.toar/landsat_met.c
> A    i.landsat.toar/Makefile
> A    i.landsat.toar/earth_sun.h
>  U   i.landsat.toar
> Checked out revision 45916.
> Compiling <i.landsat.toar>...
> /usr/lib/grass64/include/Make/Grass.make:415: warning: overriding commands
> for target `/build/buildd/grass-6.4.0/dist.grass64'
This is a packaging error as well as bug
 http://trac.osgeo.org/grass/ticket/620
and perhaps also
 http://trac.osgeo.org/grass/ticket/1180
The latter one has a test-fix in 6.5svn, does it work if you try
that version? Then we could backport it to 6.4.x.
Markus
