[GRASS-user] Re: Python-Loop over points
Moritz Lennert
mlennert at club.worldonline.be
Wed Apr 13 09:31:20 EDT 2011
Johannes Radinger <JRadinger <at> gmx.at> writes:
> Am 06.04.2011 21:56, schrieb Glynn Clements:
> > Johannes Radinger wrote:
> >> I've got a first basic idea but it isn't working yet completetly.
> >> I wanted to loop over the pointfile to use the single points for other
operations
> >> like the r.stream.basins module. Most of these modules do also except
coordinates.
> >> So here is one solution but hopefully someone know a better one:
> >> 1) add two new columns to the pointsfile and populate it with the X
> >> and Y coordinate (v.db.addcol and v.to.db)
> >> 2) use v.db.select-command in a for loop and pipe the X.Y
> >> coordinate-pair to a variable, like (to loop over the first 5 points
> >> in a pointfile):
> >> def main():
> >> for i in range(5):
> >> where ="rowid = "+str(i)
> >> p = grass.pipe_command("v.db.select", flags="c",
map=options['input'], columns="X,Y",
> where=where, fs=",")
> >> print p
[snip]
> Do you think that is the best way to loop over points..?
I think it would be easier to loop over the category values of your points,
create a temporary map containing the current point, run r.stream.basins on that
point, etc. Something like this (untested):
listpoints = grass.read_command('v.db.select', map='YourPoints', column=cat,
flags='c')
for pointcat in listpoints.splitlines():
outputname = 'output' + pointcat
grass.run_command('v.extract',
input='YourPoints',
where='cat = ' + pointcat,
output='tempmap',
overwrite=True)
grass.run_command('r.stream.basins',
dir = 'flow_direction',
points = 'tempmap',
basins = outputname)
Moritz
