SV: SV: [GRASS-user] Raster addition -Solved
Martin Album Ytre-Eide Martin.Album.Ytre-Eide at nrpa.no
Thu Apr 14 09:52:29 EDT 2011
Don't know who of you led me in the right direction, but eventually the line:
"C=A + if(isnull(B),0,B)" in the manual solved my issue.
New_map = if(isnull(old_1),0,old_1) + if(isnull(old_2,0,old_2)) + etc  and a following new_map=if(new_map>0,new_map,null())
I had four maps in my case, and that is why "new_map = if(!isnull(old_1) && !isnull(old_2), old_1+old_2,
if(!isnull(old_1) && isnull(old_2), old_1, etc)" would become to long (4!=24 statements?)
Thank you both Johannes and Moritz.
Martin
-----Opprinnelig melding-----
Fra: Johannes Radinger [mailto:JRadinger at gmx.at]
Sendt: 14. april 2011 15:13
Til: Martin Album Ytre-Eide; mlennert at club.worldonline.be
Kopi: grass-user at lists.osgeo.org
Emne: Re: SV: [GRASS-user] Raster addition
-------- Original-Nachricht --------
> Datum: Thu, 14 Apr 2011 14:31:32 +0200
> Von: Martin Album Ytre-Eide <Martin.Album.Ytre-Eide at nrpa.no>
> An: \'Moritz Lennert\' <mlennert at club.worldonline.be>
> CC: "grass-user at lists.osgeo.org" <grass-user at lists.osgeo.org>
> Betreff: SV: [GRASS-user] Raster addition
> I would like the NULL values that overlap with none NULL values to be
> treated as 0, and still have NULL values where both maps have NULL
> values. The combined map would be a large map with NULL values and added values.
that is possible with the r.mapcalc and a if condition like:
if(map A &&& map B, 0, null())
something like that (untested) might work. the null () provides NULL values where the condition is false. The triple &&& is the logic and (treats NULL values different from double &&).
see: http://grass.fbk.eu/gdp/html_grass64/r.mapcalc.html for more information.
/j
> Maybe the best way is to use r.null and set NULL values to 0. Add the
> maps and then convert the 0 values to NULL values?
> Or could one set the value in the if statement to be a the sum of maps
> somehow? I guess my biggest problem is summing with NULL values -
> maybe there is a way to treat NULL values as 0? I'll have a look at
> the man page
> Thanks,
> Martin
> Fra: Moritz Lennert [mailto:mlennert at club.worldonline.be]
> Sendt: 14. april 2011 14:15
> Emne: Re: [GRASS-user] Raster addition
> On 14/04/11 13:54, Martin Album Ytre-Eide wrote:
> > Hello.
> > I am trying to add some raster maps. I thought I could do this in
> > r.mapcalc, but "new_map= old_1 + old_2" seems to produce a map where
> > the maps overlap and ignoring areas where only on of the maps have
> > values.
> This is due to the way r.mapcalc handles NULL values. See the man
> page, section NULL support for an explanation.
> > I would like to do something similar to "v.overlay operator=or".
> > Anyone who knows how to do this?
> It depends on what you want the new map to contain as values. If you
> want to add the value of old_1 to old_2 in places where they overlap,
> one way would be to transform your null values to 0 using r.null null=
> and then applying your formula.
> If you just want a (any) value where one of the maps is non-null, then
> you can use if. Something like this (untested):
> new_map = if(!isnull(old_1) || !isnull(old_2), 1, null())
> which should give you 1 where any of the two contains a value and a
> NULL value elsewhere.
> Moritz
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
GMX DSL Doppel-Flat ab 19,99 Euro/mtl.! Jetzt mit gratis Handy-Flat! http://portal.gmx.net/de/go/dsl
