[GRASS-user] Error while running v.db.addcol
    Markus Neteler
    neteler at osgeo.org
    Thu Apr 14 15:49:58 EDT 2011
On Thu, Apr 14, 2011 at 6:13 PM, Jenny Turner <jennyturner1980 at gmail.com> wrote:
> Greetings
> I0'm using winGRASS.
Please always indicate the version...
> When I run v.db.addcol in my WinXP I get this error:
> Default driver / database set to:
> driver: dbf
> database: $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
>       0 [main] sh 5240 open_stackdumpfile: Dumping stack
> trace to sh.exe.stackdump
>       0 [main] sh 5436 open_stackdumpfile: Dumping stack
> c:/grass6/scripts/v.db.addcol: [: : integer expression
> expected
-> problem
>       0 [main] sh 2264 open_stackdumpfile: Dumping stack
>       0 [main] sh 3416 open_stackdumpfile: Dumping stack
> ERROR: Column <cat> not found
> But when I run in Win7 or other Win Machine (XP also) i do not get this
> error. Any explanation for this weird incident?
Some fixes have been applied recently
http://trac.osgeo.org/grass/log/grass/branches/releasebranch_6_4/scripts/v.db.addcol
which are available now in GRASS 6.4.1.
If you can, please update to this bugfix release. But maybe others
have an idea, too.
Markus
