[GRASS-user] snap point to line/break line at given points
Micha Silver micha at arava.co.il
Mon Apr 18 07:40:01 EDT 2011
On 04/18/2011 01:55 PM, Micha Silver wrote:
> Maybe a few more details might be helpful:
> If you want to first get the coordinates of the new points along the
> (simplified) river line,
> (starting with a line vector 'river' and a set of points 'old_pts'
> displaced from the line) you first do:
> ~>v.db.addtable old_pts col="x double precision, y double precision"
> then:
> ~>v.distance --o to=river from=old_pts out=connectors upload=to_x,to_y
> col=x,y
> This puts the *new* X-Y coordinates of points exactly on the river,
> and at the node of perpendicular 'connectors' from the old points to
> the river into the old_pts attribute table.
> Now:
> ~>v.db.select -c old_pts col=x,y >new_pts.txt
> ~>v.db.select -c old_pts fs=, col=x,y | v.in.ascii  out=new_pts
> THis gives you both a new point vector of the points along the river,
> and a text file of their coordinates. Next, I used Moritz's method to
> split the river at these new points, in a loop like:
> ~>while read coord; do v.edit river tool=break coord=$coord; done <
> new_pts.txt
> This leaves you with a multi-segment line vector, split at the new
> points.
>> v.net option=connect + some cleaning afterwards might be another
>> possible solution. For each point, it will create a line connecting
>> it to the river, breaking the river at the intersection.
>> v.distance should be able to do the labelling for you.
> I tried this part, but couldn't get it to work :-( .
> So I don't know what to suggest to get the cat values from the new
> points into the river segments...
Update:
I have found a kind of work around to get the same cat values in both
the points and river segments, although it's a bit "backwards". THe
modules v.distance and v.what.vect can only connect from a point vector
to another line or area vector. Then values from the "to" (line or area)
can be uploaded to the points. So if I reset the categories in the river
line vector - so that each segment has it;s own cat, then I can upload
those cat values into the new points vector. Here's the procedure:
FIrst blow away the existing categories in the river vector and recreate
a new vector with new category values:
~>v.category river opt=del out=river2 --o
~ > v.db.droptable -f river2
~ > v.db.addtable river2
~ > v.category river2 out=river3 --o
  Now river3 should contain a new cat value, one for each line segment.
Check with:
~ > v.category river3 opt=print
1
2
3
And finally:
~ > v.db.addcol new_pts col="river_cat integer"
~ > v.what.vect vect=new_pts col=river_cat qvect=river3 qcol=cat dmax=0.01
creates a new column in the new_pts vector attrib table called
'river_cats' with values matching the adjacent river segment.
Regards,
Micha
> Regards,
> Micha
