[GRASS-user] snap point to line/break line at given points
Johannes Radinger JRadinger at gmx.at
Fri Apr 22 10:15:38 EDT 2011
Am 22.04.2011 um 13:22 schrieb Moritz Lennert:
> On 22/04/11 11:34, Johannes Radinger wrote:
>> About my situation: I've got a river network, which
>> is a polylinefeature set with 43 lines (43 IDs) included (tree-like shape of a rivernet)
>> all with the same cat-value (1).
>> Now I would like to unite/merge the lines to one feature (1 ID) if that is possible
>> and break that single element at given points with v.edit...Because if I break
>> now at around 40 positions I get over 80 segements (40 old segements and which
>> are broken again at different positions) but there should  be only
>> 41 or so...
>> so how can I handle that and assign unique cat values for each segment...(at the
>> moment the don't have to be the same like the breakpoints, just unique values)
>> any suggestions?
> v.edit tool=catadd id= ?
Sorry but I am still confused how to do the break.
In the Attachment there is a GRASS-exported shp.-file with my
rivernet consisting of 43 single lines.
I want to break that river at e.g. 3521021.43671,6041340.79067
which is one point (out of others) along the river.
In the end I want two features/categories one on each side of the break.
what are the exact steps especially when I want to do it with several points
(I know the procedure with a python for loop in combination with v.edit).
Type: application/zip
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20110422/c3dd6884/rivernet-0001.zip
> Moritz
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
