[GRASS-user] Re: Grid
vinod kumar nani.kunithi at gmail.com
Thu Apr 28 09:45:32 EDT 2011
Hi Hamish,
Thanks for providing information and i will try to do in the following way
as Laura did.
Cheers,
nani
On Thu, Apr 28, 2011 at 2:43 PM, Hamish <hamish_b at yahoo.com> wrote:
> vinod kumar wrote:
> > I want to make grid using  grass. Can anyone help me.
> you might have a look at Pavel Sakov's gridgen
>  http://code.google.com/p/gridgen-c/
> I know you want to make a TIN, but really you probably don't need a
> TIN at all.... there are much better ways to represent a surface and
> while I'm ignorant of your plans I suspect that you'd just be making
> extra work for yourself.
> As mentioned earlier, you also might have a look at Laura Toma's r.refine:
>  http://www.bowdoin.edu/~ltoma/research.html
> which will reduce a DEM to a TIN.
> Hamish
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110428/d08314a2/attachment-0001.html
